do you know how to open the headlight unit???
anyone out there know how to open the headlight unit so i can get the condemsation out?? i cant take it to the dealer so dont tell me to go i would rather open it up, clean it out, and close it back up. so anyone with info and directions please let me know.
Originally Posted by jdm_euroR
i understand that but i want to open them and smoke the inside....
Also, you'll need to seal them again and that is the pain.
iVTEC no koe
If the sealing process is the same as previous Honda/Acura headlight assemblies, I do believe people bake the assembly in the oven, at 350F for about 5-7 minutes and pry the housing open.
Originally Posted by Alin10123
Speaking of warranties. Make sure you dont void the warranty while attempting to do this.
Originally Posted by moda_way
It actually does void the warranty and I'm pretty sure Acura can tell if someone has opened it.... b/c we're not nearly as clean putting stuff back together.
Especially since i bet the headlight assemblies aren't cheap either. So be careful.
I am Ahab!
You should have them replace the leaky ones then tell them you want to keep the old ones. I'm pretty sure they'd give them to you. THen you can do the work on those and have a back up set.
tony's right ... you should find out if they would be actually replacing the headlights with new ones and if so you can DEFINITELY get your old pair back no problem
I am Ahab!
Forgot about this.
I'm getting my drivers side light replaced Saturday because of fog. Glad this thread came up I've gotta ask more mine back.
I damn near forgot.
I damn near forgot.
I am Ahab!
Strange it's under warranty here.
btw found out today they can't give you the parts when the work is done under warranty. They have to send the unit back otherwise they don't get covered for the money.
SidhuSaaB
05-30-2020 12:40 AM
