do you know how to open the headlight unit???
Old Dec 23, 2005 | 11:50 PM
jdm_euroR's Avatar
anyone out there know how to open the headlight unit so i can get the condemsation out?? i cant take it to the dealer so dont tell me to go i would rather open it up, clean it out, and close it back up. so anyone with info and directions please let me know.
Old Dec 24, 2005 | 06:02 AM
1MeanTSX's Avatar
THIS SHOULD BE UNDER WARRANTY bring it to your dealer, there was a service bulletin about this problem
Old Dec 24, 2005 | 10:11 PM
jdm_euroR's Avatar
i understand that but i want to open them and smoke the inside....
Old Dec 25, 2005 | 05:16 PM
moda_way's Avatar
Check my cardomain... I tore down a lense. FYI, good luck getting to it... takes heat to get the seal to get soft enough.
Also, you'll need to seal them again and that is the pain.
Old Dec 25, 2005 | 05:53 PM
Alin10123's Avatar
Speaking of warranties. Make sure you dont void the warranty while attempting to do this.
Old Dec 26, 2005 | 11:13 AM
HoRRo's Avatar
iVTEC no koe
If the sealing process is the same as previous Honda/Acura headlight assemblies, I do believe people bake the assembly in the oven, at 350F for about 5-7 minutes and pry the housing open.
Old Dec 26, 2005 | 11:32 AM
JTso's Avatar
It seems like a lot of work to attempt to fix it yourself, especially it's under warranty and you don't know how to do it. Unless you don't have a TSX...
Old Dec 26, 2005 | 01:31 PM
moda_way's Avatar
It actually does void the warranty and I'm pretty sure Acura can tell if someone has opened it.... b/c we're not nearly as clean putting stuff back together.
Old Dec 26, 2005 | 06:09 PM
Alin10123's Avatar
I know lol.
Especially since i bet the headlight assemblies aren't cheap either. So be careful.
Old Dec 29, 2005 | 10:01 PM
jdm_euroR's Avatar
oh i have a tsx and i will be careful and if i mess up i will just buy a new pair no problem with that so thanks...
Old Dec 29, 2005 | 11:05 PM
tony4311's Avatar
I am Ahab!
You should have them replace the leaky ones then tell them you want to keep the old ones. I'm pretty sure they'd give them to you. THen you can do the work on those and have a back up set.
Old Jan 5, 2006 | 07:56 PM
AZTSX's Avatar
tony's right ... you should find out if they would be actually replacing the headlights with new ones and if so you can DEFINITELY get your old pair back no problem
Old Jan 5, 2006 | 10:17 PM
tony4311's Avatar
I am Ahab!
Forgot about this.
I'm getting my drivers side light replaced Saturday because of fog. Glad this thread came up I've gotta ask more mine back.
I damn near forgot.
Old Jan 7, 2006 | 04:59 PM
EuroAccord2.4AT's Avatar
Type-S user
My local dealers says it's not under warranty, new lights will have the same problem.
I got 2 euro accords over here and they both have this problem.
Old Jan 7, 2006 | 05:41 PM
tony4311's Avatar
I am Ahab!
Strange it's under warranty here.
btw found out today they can't give you the parts when the work is done under warranty. They have to send the unit back otherwise they don't get covered for the money.
Dec 7, 2020 05:39 PM
SidhuSaaB
May 30, 2020 12:40 AM
Feb 25, 2020 09:57 AM
Aug 15, 2019 12:58 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
