DC SPORTS HEADER Hissing Sound
Hey everyone, I have a little problem or at least I think i do. I just got my DC SPORTS Headers installed yesterday and i notices a hissing sound when i accelerate. Does anyone know what it is or is that normal? I read some of the treads on here but i didnt really find the same problem i have , i mean RIGHT after the install it was making that hissing sound. By the way i have a Injen CAI, Comptech Exhaust, and of the headers.
HELP!!
HELP!!
I would double check the installation and look for leaks, then tighten nuts/bolts if necessary. If that checks out, then the sound is most likely coming from the flex pipe design without the inner mesh.
i just got mine installed a few weeks ago on my 2006 there is a hissing noise at low rpms but once i get some power goin it stops. i took it back to the body shop they checked everything they ssaid its fine. i kinda like it
i have to say, it did hiss a whole lot at the beginning....but i had a broken gasket....now it just hisses a little. but it still hissessssssssssssssssssssssssss. it should be heard, but not overwhelming, just in low range when your getting the car going.
I read a lot about the DC header hiss but I don't have it as far as I can discern. I'm not complaining, just saying I think a lot of them do and some don't but it's not indicative of a problem.
Thread resurection!
I just had a Topspeed/DC replica header installed on thursday. I do hear the hissing. However it's so bad that today we put the car back on the lift to check for leaks. We cannot find a leak so it may be normal.
My question is, how loud yours are? Mine is actually louder than the Injen CAI when I go full throttle, or mid throttle. Probably because the sound is closer to the cabin than the CAI. Would changing the flex pipe help this problem. I'm not sure I can keep this on with that awful noise.
Thanks.
Thanks.
A double-walled flex pipe will significantly reduce the noise, assuming all other factors are equal. Before doing anything drastic, check to make sure it was properly installed, it isn't damaged, and you don't have any big air leaks.
I went ahead and did this on my DC header.
Like I said we put it back on the lift to look for leaks and could not find any. It sounds like that though, an air leak. There is also a broken whistling noise when more air is going thru (ie full throttle).
I knew I would have more sound but not like this. This sound does not belong on a car like that. It sounds like I need a muffler job!
Also Reach, did you change yours for a DC or Comptech? I can't remember. Did you change it for that problem? If it's the DC, does it have the same hiss than the Topspeed?
Thanks.
Thanks.
Originally Posted by KingTSX
Anyone have the dimensions of the flexpipe on the Topspeed headers?? I am looking to find a replacement double wall flex to put in its place...thanks in advance....
Originally Posted by jlukja
It should be identical to the DC Header since the Topspeed is a knockoff of that design.
Originally Posted by vilmar5
I'm not sure it is. Mine looks like only 4 inches for the flex pipe. It's definetaly not 6 inches.
I havent' measured mine, but I do know that it was a little short and Mr. Heeltoe had to "pull in" the cat a little bit (1/2" to 1") to make the connection.
I had Mr. Heeltoe put on the Topspeed header this past Friday. We quickly discovered that there is a hole in the flexpipe and it makes a horrible sound, like a fartcan exhaust with a hole in it. The header is on the car right now. I can feel the performance improvement although it seems to sputter a bit when I go from low throttle to full throttle (this is probably due to the hole). Anyway, I will be replacing the flexpipe as well. It should be identical to the DC Header since the Topspeed is a knockoff of that design. Here is a link to a post by JTso where he discusses the flexpipe replacement: https://acurazine.com/forums/sho...352&postcount=7
Originally Posted by JTso
There is a gap between the header (regardless of OEM, DC, Comptech or Topspeed) and the cat converter. The gap is not a problem with the OEM header as it has a spring loaded upper mount plus a flex pipe. However, this gap could potentially be a problem for other headers as it puts additional stress on the flex pipe.
J, When you installed your modified DC header did you have to pull the cat towards it a bit to make the connection? I wonder if some of that "play" is to allow for metal expansion at exhaust temperatures.
Hey Jlukja, it seems like all DC header owners have had to pull on the CAT/exhaust a little bit to bolt it up. When you change your flex pipe, you might want to have them extend the apipe or cut off less piping if possible, so that the new a-pipe is longer than the previous one. Good luck man. Once you get that fixed, I think you'll be a lot happier and hopefully be able to recognize any power gains a little better. Good luck man
JTso, I had the shop that did my weld job add 1/2" to the overall length of the a-pipe when they did my re-weld. The end effect was that I now had to actually push the exhaust just slightly backwards to bring the components together. That being said, it still fits just fine on the rubber hanger.
As a side note, I made markings on the pipes to compare initial and final length after re-weld. Unfortunatly the guy destroyed them. So, I have no idea what the actual, measured, added length was. I asked him again at the end and he says he was careful to extend it 1/2" exactly, but I cannot be sure. Either way, its a good system now, quiet and efficient at 26mpg primarily city driving w/ my mods.
Also, I know JTso is using the original DC flex pipe, but with all due respect, it seems (correct me if I'm wrong man) that he does not rack up as many hard driving miles as some of us depending on the TSX as our only car for 12K+ miles a year.
JTso, Reach, does this make sense?
I measured my Topspeed this afternoon. The mesh portion of the flex pipe is exactly 3" long and it has a 3/4" lip on either side. It appears that each lip slides over the solid pipe on either side and is welded at the joint. The solid pipe I measured at 6-5/8" circumfrence which would indicate a 2"OD solid pipe and a 2"ID flex pipe. If the repair requires the cutting of the straight pipe right at each weld line then the replacement would need to be at least 3/4"+3"+3/4" plus, lets say 1/2" on either side to allow the new lip to overlap the solid pipe for welding. That gives a total of 5-1/2" from lip edge to lip edge. To that, if I want to add another 1/2" to the overall lenght then I would be looking at a flex pipe that is 2"ID and 6" long, edge-to-edge.
Thanks. So the Topspeed has a 2" pipe versus of the 2.25" for the DC? I'm about ready to order the new flex pipe. I'll have to confirm this before I do.
All of the headers move down to a 2" (not 2.25") internal diameter, as that is the size of the port into the cat. I'm not sure that 0.25" at the flex pipe section is going to make much difference, since it still goes down to the correct 2" at the flange.
Johnny?
Johnny?
Jan,
Sorry I somehow missed your earlier comments. I would use a 2" x 6" double walled stainless flex pipe from performance curve. This is what I used when I did my DC re-weld. In fact, I have both 2.25" and 2" pipes at my house, let me know which you'd prefer.
