coincidence or from condensation?
Old Nov 9, 2012 | 09:26 PM
J_Phil's Avatar
Question coincidence or from condensation?
my tsx recently fell victim to he condensation in headlights problem. but me being the procrastinator i am just decided to wait for a bit as i didnt think that small amount of water inside would do any harm. just today when i turned the headlights on, the low beam in the headlight wont come on but the rest of the lights all work fine. is this a mere coincidence? or did the low beam being in a more prolonged use somehow made it more susceptible to water damage? theres not enough water in the to slush around its just droplets
Old Nov 10, 2012 | 12:03 PM
Simba91102's Avatar
Old Guy
I don't usually respond to people who are too lazy to use capital letters (we're not texting here), but.... My comment is two pronged. First of all, it doesn't really matter since the light needs a new bulb, and/or be repaired/replaced. I think the coincidence is too big though. I'll assume you didn't have the recall performed, or it's leaking anyway. An Acura dealer should be able to tell you if it was the water or just an expired bulb (which should be replaced in pairs by the way....).
Old Nov 10, 2012 | 07:21 PM
J_Phil's Avatar
First off, thank you for the response. Second, I really didn't think correct punctuation and so on was such a big deal here, but if it gets me more responses then sure why not. As for the recall unfortunately its been done by the owner before me. Whatever course of action I choose to take, I can assure you the dealer will be MINIMALLY involved if at all now that their hands are pretty much wash clean of me (all recalls fulfilled). I'm hoping with as much water that has got in, the crack/opening should be easy to find and seal. It was only after one touchless carwash and BOOM, condensation :/
Old Nov 14, 2012 | 06:47 AM
npolite's Avatar
Usually if any water has hit the bulb while it was hot, it will damage the bulb. Most times that I have seen this, it usually cracks the bulb. Not fun to have to remove the light assembly to get the glass pieces out of the housing.
Hopefully your dealer will be able to take care of it.
Old Nov 14, 2012 | 11:27 AM
J_Phil's Avatar
But see the thing I'm getting at is that isn't there a lens covering the bulb? I thought the bulb itself was sealed off from the headlight case?
Old Nov 14, 2012 | 08:03 PM
Simba91102's Avatar
Old Guy
I don't think so, judging by what you see when the light is on. I haven't had to replace a bulb yet, so I haven't been in there (headlight casing), though I am on watch. With my 05 in service 7 1/2 years now and with over 175K miles on it, it's finally starting to fall prey to nickel and dime stuff. I'm half expecting a bulb (an HID I mean) to sign out anytime now.
Old Dec 11, 2012 | 08:14 PM
Hardliving's Avatar
What recall are you speaking of. Just bought my 07 TL. I have slight condensate on both sides. Like J_Phil it's not even a enough to make a drop. Is it a issue I can contact dealer to repair or what?
Old Dec 14, 2012 | 09:13 AM
Simba91102's Avatar
Old Guy
There was a recall for some first gen TSX's that were getting water inside the headlight casing (this was a number of years ago). TSX only I believe. Oh, and I think condensation in not unusual. The bulbs I believe do build up some heat inside the casing, and this will produce condensation in some atmospheric conditions.
Old Dec 14, 2012 | 09:32 AM
nj2pa2nc's Avatar
it's a car-drive it
My tsx has the same problem. Condensation is gone but the low beam would not go on. Bought a low beam from AutoZone (not cheap) and had it put in. Did not work so returned bulb for a refund. Have a appt. With a local mechanic to check out the problem.
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
ceb
ILX
Sep 27, 2015 10:56 AM
2Quik
Sep 21, 2015 08:51 AM
Fibonacci
Money & Investing
Jan 23, 2009 12:16 AM
