code P0498 changed & engine light on again
Old Sep 7, 2012 | 09:26 PM
tazzy's Avatar
3rd Gear
My car failed NJ inspection with the code P0498 so we changed the evap canister vent shut control circuit and the light is back on. Does anyone know why? what else is there to fix? We are at our wits end and I need to take the car back to inspection!
Old Sep 8, 2012 | 02:27 AM
Simba91102's Avatar
Old Guy
Did the light ever go out? Did you try disconnecting the battery to reboot everything?
Old Sep 8, 2012 | 11:42 AM
tazzy's Avatar
3rd Gear
Simba - The light went out after replacing part but came right back on. I did not know to disconnect battery to reboot systems....but makes sense to do so as it is a computer working. Will give it a try! Thanks!!!!
Old Sep 8, 2012 | 02:34 PM
RA032025's Avatar
in the 24th and a half...
P0498 - Evaporative Emission (EVAP) Canister Vent Shut Valve Circuit Low Voltage
Funny, the first check is for shorts, then replace EVAP canister vent shut valve, then update or substitute a know good ECM/PCM.
Sounds like a rouge short is the best bet. I'm not sure why you replaced the control circuit.
Old Sep 9, 2012 | 09:56 PM
tazzy's Avatar
3rd Gear
DuckDodgers- we wish we had known that this code does not always mean that it IS the EVAP!! We have found out the hard way! Anytime the comp has read a code on a car,it has been the actual problem until my Acura! It has always been dead on with our volkswagens!
So we are in a new learning curve apparently! Please feel free to offer any other suggestions!! Thank you for the advice!
Old Sep 10, 2012 | 09:16 AM
RA032025's Avatar
Most of the PGM-FI troubleshooting is focuded on ruling out shorts, opens, and loose connection BEFORE changing out parts.
Exactly what part was replaced? Is the mechanic you are using an Acura dealer or specialist with access to a HDS? If not, does he have the shop manual to interpret the codes, as generic code readers are weak diagnosic tools without each manufacturers code list.
Old Sep 18, 2014 | 06:00 PM
FreggieTL's Avatar
Hi everyone. am very new on this forum. I have save issue. MIL is on and threw a code P0498. Pls i will like to know the steps to take in resolving this problem. The MIL makes be feel sick every time i see it on my instrument panel
mada51589
Jan 9, 2025 04:40 PM
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
whitesoxsfan12
Sep 7, 2015 04:07 PM
Papa Roe
4G TL Problems & Fixes
Sep 1, 2015 09:41 PM
