Clunk in the front?
Old Apr 17, 2009 | 03:35 PM
shmork53's Avatar
Clunk in the front?
So I have a 2004 MT and I have been having this clunk type noise coming from the passenger side of the car when I go over a speed bump or any sharp vertical change (like a small lip onto the sidewalk). Now it is starting to make the same noise occasionally when I make a sharp turn especially at low speeds like in a parking garage.
I took into Firestone today to have them test the front suspension and they said they found nothing wrong. I believe the noise might be coming from a tie rod end or ball joint. What is your guy's input? Tonight when I get home I might bust out the jack and take another look, or just bite the bullet and take it to Acura or a Honda dealer. Any input on what else it could be and/or if anyone else has experienced similar issues.
I have heard that sometimes the TIEN springs can make a little noise. If anyone has experienced this can you please describe it.
Thanks everyone.
Old Apr 20, 2009 | 12:59 PM
globlctzn's Avatar
I have a 04 manual also and this sounds alot like the clunk I was hearing. It ended up being the radiator vibrating and bouncing around under the hood. I haven't found a permanent fix yet but for now a shop rag is wedged between the front of the car and the radiator to keep it from moving. No more clunks when I go over bumps.
Old Apr 27, 2009 | 05:13 PM
gbaker's Avatar
Interesting... I'll have to check out the radiator mounting. I have the same clunking, very intermittently on my 04 TSX 6MT. I mostly notice it on slow, near full-lock turns over cambered surfaces (ie: pulling into a driveway or into an uneven parking space). It's definitely coming from the front. I thought maybe the struts or something in the suspension might have been loose, since I upgraded to the A-Spec suspension several years ago.
Old Apr 27, 2009 | 05:44 PM
shmork53's Avatar
Interesting, I will take a look at the mounts for the radiator. My problem sounds a little too solid to be a radiator and it also happens ever once in a while when I returning from a full lock turn, like the ball joint or tie rod end is reseting. After talking to some mechanics, they and I think its the lower ball joint or wheel bearing, so both of those are getting replaced this weekend.
I will keep you guys posted if it resolves.
Old Apr 28, 2009 | 09:14 AM
05tortsx's Avatar
i had a similar clunk noise in the front end as well. dealer re-tighted the radiator mounts and put foam insulation where it was hitting the frame. noise is gone. the odd time you can still hear it though. maybe i need to re-tighted again or add additional foam.
Old Apr 28, 2009 | 11:47 AM
lcrazyaznl's Avatar
CL9 ABP
I think thats where my sound came from two when ever I started the car I heard a clunk.
It was also one of the upper control arms that was worn out after so many potholes in nyc.
Feb 25, 2020 09:57 AM
marcelft
Jul 10, 2018 06:17 PM
Sep 17, 2015 10:16 AM
1Lieutenant
4G TL Problems & Fixes
Sep 10, 2015 08:39 AM
08 NBP TL
Sep 8, 2015 08:49 PM
