check emission system. help
Old Sep 27, 2012 | 05:25 PM
guojunmai's Avatar
6th Gear
Recently while I was driving the VSA check light and the emissions check light went on. The
car
also jerked. It is a 2006 automatic TSX. sometimes there is no power when the accelerator is stepped on the car . If the car is turned of for a couple seconds then turned on again, everything is fine for about 3 min of
driving
before the above occurs again. I have not taken it to the dealer as of yet, but will. In the meantime..... any idea's on what the problem may be?
Old Sep 27, 2012 | 07:29 PM
TexasHonda's Avatar
Get the check engine light code and someone may be able to help. W/o something it's hopeless.
good luck
Old Sep 27, 2012 | 08:57 PM
guojunmai's Avatar
6th Gear
i checked the code p1734 and p0780
Old Sep 27, 2012 | 08:58 PM
guojunmai's Avatar
6th Gear
i did check the code. they are p1734 and p0780. i think i need go to the dealer tmr
Old Nov 5, 2012 | 04:01 PM
Madame Meow's Avatar
P1009 check emissions light, transient vsa light
Also engine surged at idle. Stopped, restarted, vsa did not illuminate, check emissions llight was steady ON. I drove home, parked overnight.
Took my 2006 tsx, manual trans, 69.5k miles, in to dealer today; they determined P1009 was the error code.
Root cause was low oil level. Lo Oil Press indicator never came on. Hope this helps someone else!
Old Nov 6, 2012 | 05:01 PM
RA032025's Avatar
in the 24th and a half...
OK, guojunmai, you have a transmission issue.
P0780 - Shift Control System
P1734 - Shift control system; Shift solenoid valves B or C stuck OFF or Shift valves B or C stuck
With transmission issue, the first check is fluid level. If your transmission fluid is too low, the valves malfunction and the transmissions can start throwing codes. Top it up, if it's low. Also, what color is the fluid and how does it smell?
If that doesn't fix it, it's dealership, independent specialist or transmission shop.
Madam Meow, P1009 is VTC Advance Malfunction, as you now know, famously caused by low oil levels. Don't rely on oil pressure light, that warns far too late. Check oil level about once a month (more if you burn oil), about the same time you check tire pressure (remember the spare too).
Aug 15, 2019 12:58 PM
SpraykwoN
ILX
Sep 24, 2015 05:20 PM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
heykosal
1G RDX Problems & Fixes
Sep 21, 2015 09:41 AM
Sep 17, 2015 09:01 PM
