Cast & Camber Recom.
Old Aug 23, 2007 | 06:54 PM
jiggaman10's Avatar
One day at time
Post Cast & Camber Recom.
Good day to all, I have a 05' TSX lowered with Eibach proline springs and i'm working of a second set of tires which i'm not to happy about! If they're any of you out there that could recommend a Camber kit please do so and give a ruff idea of what the kit runs for i would gladly appreciate it....Peace
Old Aug 23, 2007 | 07:24 PM
PACman's Avatar
Ingalls or SPC. About $120-150ish. Our forum vendors are great contacts for these parts.
Old Aug 23, 2007 | 07:40 PM
jiggaman10's Avatar
One day at time
Right on, Good looking out!
Old Aug 24, 2007 | 06:43 AM
moda_way's Avatar
I'm guessing you mean camber and toe adjustment.
Old Sep 16, 2007 | 05:16 PM
luder917's Avatar
SSM FTW
how long did your tires last?
Old Sep 16, 2007 | 07:21 PM
afici0nad0's Avatar
i'm assuming you're only looking for a rear camber kit?
Old Sep 16, 2007 | 10:52 PM
Tangoman's Avatar
Caster isn't something you can adjust on the TSX... I assume that you mean Camber and Toe adjustment.
Depends on how much you want, but really anything over -1.5 degrees in the front will wear your tires (but it might still be too slow for you to care) your toe should be set at 0, you don't want to wear tires like crazy, especially if its a daily driver. -1 degrees camber in the back is what the car comes with stock, that should stay the same if you can swing it, otherwise, -2 works great, but will wear tires.
emailnatec
29
Sep 28, 2018 04:27 PM
Jul 16, 2017 07:33 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
0opie
Sep 22, 2015 04:15 PM
