Car Idling really low
Old Jul 24, 2006 | 10:19 AM
CCColtsicehockey's Avatar
My car is idling really low at around 500rpm and has stalled twice. This has started since the install of my comptech header and rt cat. I now have injen intake / comptech header / rt cat / greddy exhaust if that helps at all.
Old Jul 24, 2006 | 10:22 AM
jiggaman's Avatar
I spend 2 much time here
just a guess, but maybe it has to do with the A/F ratio being off now?
Old Jul 24, 2006 | 10:41 AM
why would it be down now. to be exact my car used to be running really rich for some reason before getting the header and cat.
Old Jul 24, 2006 | 10:43 AM
guess its time to get a reading from my car for a/f ratio.
Old Jul 24, 2006 | 11:50 AM
jiggaman's Avatar
i bet there is a 90% chance that the RT cat is causing this issue. you might want to try putting the stock cat back on to verify this.
Old Jul 24, 2006 | 11:58 AM
Dan Martin's Avatar
Photography Nerd
Sounds like you just need some JDM gas.
Old Jul 24, 2006 | 12:51 PM
I started the car today and it was idling at around 1000 now which is more where it normally is. I just moved it out of the garage so I dont know if it will stay there but I will check later on today. I think I am going to buy the rockway unit the rmpage and tsx536 has that monitors a/f and lets me reset check engine lights and read them.
Old Jul 24, 2006 | 12:58 PM
moda_way's Avatar
moda_way's Avatar
Obviously we expect a report of your a/f ratio.
Old Jul 24, 2006 | 01:50 PM
LoveMyTL-S's Avatar
A very expensive fix
Old Jul 24, 2006 | 07:04 PM
well i tried doing a anti fouler and that didnt work so i think i broke the o2 sensor cable so how much is a new one.
Old Jul 24, 2006 | 09:56 PM
kurt_bradley's Avatar
$50 for the part. 10 minutes of your time for labor. You may need to have a PGM tester handy. You might throw a code when you pull the o2 sensor.
You may want to pull codes first and see if there was anything intermittent going off.
Old Jul 24, 2006 | 09:59 PM
joerockt's Avatar
Just dial 1911
You just need to adjust the throttle cable...
Old Jul 24, 2006 | 10:23 PM
Careful. Some members may actually go out to the garage, try this, and come back complaining...then starting stupid threads.
Old Jul 24, 2006 | 10:36 PM
will it have a long enough cable cause if you have ever looked under the car the connector for the cat o2 sensor is inside the cabin. the cable is 3 feet long.
however hopefully you are saying that I dont need the one the dealer charges 215 for.
STFU
Old Jul 25, 2006 | 02:12 PM
joerockt's Avatar
Just dial 1911
LOL...Can't wait...
Old Jul 25, 2006 | 02:13 PM
joerockt's Avatar
Just dial 1911
STFU
Still have that sand in your vagina huh?
Old Jul 25, 2006 | 04:01 PM
i wasnt really being serious and the answer to that is no.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
Bahamanurse1
Sep 10, 2015 10:05 PM
Mike Bertram
Sep 10, 2015 09:27 AM
NSolace
Sep 3, 2015 08:14 PM
