Burning Smell & Smoke...Clutch or Brakes?
More likely a sticking caliper or clutch?
Brought the car to my local Honda dealer to have what I thought was a sticking caliper piston inspected. About 3 or 4 times over the last few months there has been what seems like brake burning smell and smoke coming from the front right tire.
Dealer diagnosis is a failing clutch. Considering the positioning of the clutch, I guess that makes sense and sounds plausible. Only thing is, the clutch feels fine. No slipping that I've noticed and the car seems to drive fine. Although I can understand if its something I failed to realize if its been happening slowly. Doesn't sound the dealer took anything apart but came to this conclusion on a test drive.
Thoughts? Can a clutch burn like that yet still feel pretty normal?
Replacement clutch....$1600 + taxes
Sounds more like burning brake fluid. Does it smell like cat piss? When does it happen? Under what conditions?
If the clutch is not slipping and feels like it always has, the clutch is more than likely fine.
Check your brake fluid lines for any signs of wear or leaks and check the reservoir.
Also, that price for a clutch replacement is absolutely ridiculous and outrageous. If you ever need to replace your clutch, buy an OEM clutch kit on ebay (exedy etc.) and have a reputable local shop install it. I guarantee that the cost will be less than half of what the dealer is charging.
So its on the passenger side? Interesting.
The smoke/steam is definitly coming from the drivers side front.
131,000km or about 82,000 miles.
I had the brake fluid done today since thats what I initially suspected needed to be done anyway. Brake feel is much better.
1,600 was a Honda dealer price. Acura wanted 1,900. I've since got two other quotes of ~900.
Can I get some ideas on what type of testing I can do to determine if the clutch is slipping? I thought Cruising in 5th or 6th and flooring it would show slipping but the rpms climb...slowly but they climb.
Driver/Detailer
Sorry, I meant front left from my orientation when I am sitting in the car. So yes, front driver's side in your car. I haven't seen a clutch give out smoke before on a street car with a street clutch.
one easy test would be to try to start the car from a stop using only the clutch. if you can get the car to start moving without using the gas pedal, then the clutch should be in pretty good shape.
have you checked for leaks in the area? could be any sort of fluid leaking and just burning off.
is the clutch fluid cylinder full?
Not happening.
Do you mean just press the clutch and see if the car rolls? It does.
Its garage parked and I haven't noticed any leaks on the concrete.
Will do.
This morning at one point at about 120 the car steering was shuttering/vibrating and only got worse when I applied the brakes. It only happened that one time and my drive is all highway.
Someone stole "My Garage"
I'd get someone to look at the front brakes. Inspect pad thickness, rotor wear, clean and lubricate the slider pins and shims.
Does your car pull left or right when the brakes are not applied? What about when they are applied?
What does the smoke smell like, and if it happens again sometime soon, get under there and try to see what area it's coming from (brakes/wheelwell, or under the car (transmission area)).
Well if that's the case, get the caliper inspected fully, ASAP. There is an increasing chance that it will get worse and worse and could seize up completely.
I meant stop the car, and try to get the car moving. it's kind of like starting from a stop, but you're not using the gas pedal.
the end result would be that the car is moving 5-10 mph and you have no feet on any pedal. and you get the car moving only using the clutch pedal. you never touch the gas pedal.
i'm going to agree that it sounds like a problem with the brakes and not the clutch.
Problem appears to be solved.
Took the car to a local shop. After driving it they didn't find anything wrong which was fine since the problem was periodic. While up on the hoist all tires except for the drivers front spun freely and there was some browning on the rotor compared to the other.
$225 for a rebuilt caliper later and I'll be crossing my fingers hoping that was it.
The car had a periodic vibration at higher speeds for some time now and its only been getting worse. I really hope this was the cause.
And he said the clutch felt fine to him.
calrow
05-03-2017 10:21 PM
GWEEDOspeedo
01-15-2016 10:39 PM
