Broken foglight relay?
Old 02-20-2007 | 01:20 AM
supraken's Avatar
I have the Ebay fogs (JDM replica styled which can fit the Euro-R lip), and recently, I haven't been able to get my fogs to work after I removed the negative wire last time.
Once I connect the negative wire and turn it on, I can hear what sounds like the relay trying to make contact, and back, and forth, etc, at a very rapid place. Sounds like a very fast ticking sound essentially.
Does this seem like I have a bad relay? Any possibility that I can fix the relay (open, clean, whatever)? If not, where can I get one of these relays so that I can use the existing sockets and such?
Old 02-21-2007 | 03:41 PM
supraken's Avatar
Anyone?
Old 02-21-2007 | 06:42 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Can you post some pics? I have some knowledge of relays and stuff, but I'm not sure what the particular relay your talking about looks like.
Old 02-21-2007 | 07:05 PM
poltergeist's Avatar
Are you sure you have a good ground? Chattering relay is often caused by a poor ground path.
Old 02-23-2007 | 08:44 AM
supraken's Avatar
This is the relay I'm talking about that came with the bootleg ebay JDM fogs:
Wiring and grounding seems to be ok, but I will check again to make sure...
quanaman
01-09-2023 07:33 PM
Kres43
1G RDX (2007-2012)
10-03-2015 07:16 PM
juanrl
09-29-2015 03:25 AM
greeneyes.hypnotize
09-27-2015 02:47 PM
Quick Reply: Broken foglight relay?
