Broken Center Console Cubby/Pocket!!!
So i was loading something and accidentally smashed in my upper cubby and when i pulled the cubby out, i realize the frame behind is broken.
Now, the upper cubby doesn't fit back in and the lower cubby's hinge is damaged. I have ordered new parts for both cubby/pockets (#18 and #16 image below) and the frame (#12) that holds both cubby/pockets. Does anyone know how to install the Frame??????
PLEASE HELP!!!
PLEASE HELP!!!
i was really really hoping i dodnt have to do that...
getting the cubby out should be fairly easy. put both ur hands inside the pocket and place them on the rubber mat then simply pull back. If its not broken like mine, it should come right out. i had to literally yank mine out.
Or, you could use cut a section from the coat hanger to form yourself a U with hook at each end. Place
them into two little slots on the bottom of the pocket (Part#15) and pull it straight out. It will not take a lot of force to remove it. You may break it by pulling too hard.
Also, be careful when removing this “pocket” because there is a small light assembly on top of this “pocket”. A great chance for you to check the bulb and replace it if nescessary. Good Luck! ! !
mlody
Dec 4, 2019 02:11 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
InFaMouSLink
Oct 27, 2015 06:52 PM
