Brakes Brakes Brakes Brakes Brakes
Old 11-03-2007, 05:17 PM
FZ427's Avatar
Very disappointed, got new rotors power slot new brakes pads Hawk 2000 miles ago and still the vibration under braking on highways speeds, what's the deal ?
Old 11-04-2007, 05:18 PM
dmbfan36_23's Avatar
are your tires properly balanced? have you had them checked?
I am lookin' to get pads and rotors and am debating whether to get power slots or brembos... 4 power slots will run me about $100 more than 4 brembos. I think I'm doing Hawk HPS pads rather than ceramics.
Old 11-04-2007, 06:47 PM
chhimp's Avatar
Check the tire balance and pads for uneven wear. Did you break in the pads correctly? Mine worked out great. No shimmy at all, just when in the morning cold it squeaks alittle and then once its warmed up, it is great.
Old 11-04-2007, 07:15 PM
FZ427's Avatar
Guys guys guys the shaking is only under braking on the highway, on street driving no problems at all. Yes I break them in correctly, drove like my mom for 1000 miles if you know what I mean.
Old 11-05-2007, 01:26 AM
SodaLuvr's Avatar
Sounds like there's either an excessive runout problem, overheating of the rotors, or improper lug nut tightening (thus causing a runout problem).
Did you clean the hub flange (area which the rotor hat mounts to) prior to installation?
If you did, the issue with your hub/spindle assembly. If the hub/spindle assembly itself has excessive runout, even if your rotor is perfectly true, you will eventually have a pedal pulsation problem as the total runout is still too high.
You need to check the runout with a dial indicator. If it's more than 0.003" of runout, it's too high. You must either resurface the rotor using an on-the-car lathe (so that the rotor is true to the hub) or use runout correction shims.
Old 11-05-2007, 02:04 PM
bhamsan's Avatar
I get this in the morning. it sucks.
Old 11-05-2007, 03:35 PM
FZ427's Avatar
SodaLuvr: Thanks for the info, I was thinking it can be hub/spindle assembly.
Old 11-05-2007, 03:43 PM
SodaLuvr's Avatar
I thiink you can purchase runout correction shims (sometimes sold as "brake align") shims from Napa.
Buy a dial indicator off Ebay for about $35. When measuring runout, be sure to install at least 3 lug nuts and torque them to 20 ft-lbs or so before measuring.
Old 11-06-2007, 10:13 AM
JyeJye's Avatar
I was thinking of Brembos for my rotor replacement with Hawk pads. I've heard the Brembos can have issues with rust. Any Brembo owners have this problem?
Old 02-20-2020, 05:33 PM
5th Gear
hpsoils's Avatar
when it comes to bleeding brakes. start at left front and work your way around .like clock.
so it would be L/F,R/F,R/R,L/R .
Old 03-07-2022, 04:57 PM
3rd Gear
acuramtereman's Avatar
I'm having noise problems with 2021 TLX type s when turning wheel hard to the left
Car makes a moaning noise when turning wheel hard left after cold startup, sounds like steering rack or something is not lubricanted well.
Sarah_Kelly (03-13-2023)
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
rockyboy
10-02-2015 10:45 PM
27trains
4G TL Problems & Fixes
09-30-2015 09:44 AM
2ManyHobbies
09-24-2015 09:23 PM
Quick Reply: Brakes Brakes Brakes Brakes Brakes
