Brake pedal sound
Old Aug 4, 2003 | 12:50 AM
XPLORx4's Avatar
My other "car" is a 4x4
Question Brake pedal sound
The brake pedal on my new TSX makes a "whooshing" sound, like air escaping, when pressed. It's actually quite loud. Is this pretty typical of the TSX?
Old Aug 4, 2003 | 02:33 AM
larchmont's Avatar
More On
Don't have it, haven't seen it mentioned by anyone.
But let's see what else turns up on here.......
Old Aug 4, 2003 | 08:08 AM
blahsome's Avatar
I have it. I plan to let the dealer check it out at the first oil change. It doesn't come from the brake itself and doesn't sound that ominous.
If you go to the dealer for this, can you post the result? Thanks.
Old Aug 4, 2003 | 02:25 PM
XPLORx4's Avatar
It's very helpful to find out if other people have the same brake pedal behavior, because it's far too common for dealers to say a perceived problem is "normal".
Old Aug 6, 2003 | 04:42 PM
sheik28's Avatar
SEEK and you shall find!! Not that I'm that religious but... BRAKE SQUEAL!!
Your brakes are fine!!!
Old Aug 8, 2003 | 08:35 PM
Krispy Kreme's Avatar
6th Gear
I hear the same sound in my TSX. I'm used to it and I doubt it's a safety issue so I don't intend to bring it in to fix (if that's even possible).
Old Sep 5, 2003 | 12:09 AM
fiya's Avatar
I have the same noise. I've asked around and heard that it's part of the cars "breaking in period" but I'm not sure. Nor did that answer come from a dealer.
Old Sep 5, 2003 | 12:34 AM
w_piti's Avatar
I have the same noise here. I guess its just normal since there has been nothing wrong with my car. I will ask my dealer when i change my oil.
Old Sep 5, 2003 | 08:31 AM
Bass Mechanic's Avatar
its normal my Pilot does it also. it is a damper that prevents you from slamming on the brakes suddenly. it works like a shock absorber only it uses air. it helps to prevent a total wheel lockup condition so the ABS have a chance to work.
for thoes of you who live in an area where it snows. you will find that if you hammer the brakes at moderate speeds with any car equipped with ABS you can stop all 4 wheels so fast that the car thinks its already stopped. therefore the ABS can't activate. ABS needs to see at least 1 wheel still turning when applying the brakes otherwise the system makes the assumption that the car has in fact stopped when it reality it is sliding.
Old Sep 5, 2003 | 09:12 AM
DEVO's Avatar
My GS-R makes this noise as well. Not a problem.
Old Sep 5, 2003 | 01:15 PM
TSXinCA's Avatar
I have the same noise too. Don't think its any kind of safety issue, just a little annoying. If anyone has had this fixed by their dealer, please let us all know.
Old Sep 7, 2003 | 05:57 PM
rhaaos's Avatar
3rd Gear
mine makes squeakin noise and its only been 600 miles...buh i dun hear any whoosing noise tho...
Old Sep 7, 2003 | 06:05 PM
blahsome's Avatar
That sound is coming from the pedal, not the brakes. It sounds like compressing some air pump. It's not at all omnious, though.
Old Sep 9, 2003 | 09:17 AM
turn up the radio and forget about it, its not a problem or flaw with the car, just the way it is.
no point in taking it into the dealer to complain about it they are just going to tell you it's normal.
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
Iain MacLeod
Sep 17, 2015 01:01 PM
pgeorg
3G RLX (2013+)
33
Sep 16, 2015 07:40 PM
Ny1718
Sep 11, 2015 09:21 AM
