Black door pillar covering
I didnt notice on the car when i purchased it two weeks ago till the pollen filled the crack in my car.. but the black pillar on the outside near the window has a huge gouge taking out of it.. i figured it would be a painted part.. but upon pulling the seal back it looks like some sort of sticker/covering put on the car.. question is does honda sell this covering as a replaceable part?
i will grab some tonight with the camera.. its the passenger door. black pillar to the right left of the window when opening the door check on the inside part near the seam.. you will see that the black covering is a sticker/layer of some sort that you can peel off
He's talking about the black door trim in between the front and rear window. It's got a matte finish, and yes it's a sticker. From what I've read it's pretty tough to remove.
Here is what you want, either part 6 or 8 depending on which side of the car you need it for:
http://www.acuraoemparts.com/delray/...All&vinsrch=no
That link is for the rear doors; you can find the front under the "Front door panel" section.
Also, here are some more OEM part sites to check out and compare prices:
http://www.acuraautomotiveparts.org/...catdisplay.jsp
http://www.acuraparts247.com/
Good luck!
-Shaun
Good luck!
-Shaun
Wow, that is greatly appreciated.. i started to pick at the sticker from the back and i can only imagine how tough it is to get it off.. let alone getting it installed and on there right.
i appreciate it as i was looking for a parts diagram
