Bad start sometimes. Horror!
Old Apr 9, 2007 | 06:18 PM
  #41
moda_way's Avatar
Originally Posted by visuelz
Haha how much are those? They look cool.
$20/ea for those. They have a set sans one of the extra connection posts for $16/ea at partsexpress.com.
Old Apr 9, 2007 | 07:46 PM
  #42
visuelz's Avatar
East Coast Crew
Maybe I just should just buy a buddyclub racing condenser lol
Old Apr 9, 2007 | 08:37 PM
  #43
moda_way's Avatar
well obviuosly we're talking about completely unnecessary parts here. these just add a little class under the hood.
Old Apr 11, 2007 | 01:07 PM
  #44
kyotousa's Avatar
Originally Posted by aaronng
No, the new TSB has nothing to do with this. With the problem that the TSB describes, one it happens, your car won't start anymore.
So basically everyone should get that fixed before it happens
Old Apr 11, 2007 | 10:49 PM
  #45
visuelz's Avatar
East Coast Crew
The battery is coming tomorrow!
Old Apr 12, 2007 | 12:58 AM
  #46
aaronng's Avatar
Driver/Detailer
Yup, that's why for vehicles with the affected VIN range, it is a recall (it is at least here in Australia).
Old Apr 12, 2007 | 09:08 AM
  #47
visuelz's Avatar
East Coast Crew
http://www.fedex.com/Tracking?langua...00359861321064
woohoo! I can't install it today though =(. Raining hard outside.
Old Apr 12, 2007 | 09:31 AM
  #48
moda_way's Avatar
Recommendation, try your hardest to not let the tie down hooks come out of their holes while you install the battery. Its a tight fit, but it is 100% doable.
Old Apr 12, 2007 | 09:43 AM
  #49
visuelz's Avatar
East Coast Crew
Hmm....I wonder if there's a picture I could see or better yet a walkthrough to this but if not I'll do my best. Should I pull on the tie downs really hard? I'm looking at Jtso's thread located https://acurazine.com/forums/showthr...ghlight=redtop . Am I suppose to be able to see it in that picture?
Old Apr 12, 2007 | 09:55 AM
  #50
moda_way's Avatar
You'll see when you go to unscrew the nuts at the top of the bracket. That is a threaded rod with hooks on the other end. As you tighten down the nuts, they pull up on the hooks at the bottom (just a solid rod) and the hooks are inserted into a tab off the metal tray. Because the width of the base of the Optima batter is larger, it is a tight fit for the hooks. Removing the battery is about as simple as putting gas in your car other than you want to remove the negative first, then the positive. Put the Positive back on first and then the negative.
Old Apr 13, 2007 | 12:04 PM
  #51
visuelz's Avatar
East Coast Crew
Hmm...am I suppose to use the tray that came with the battery?
Old Apr 13, 2007 | 12:08 PM
  #52
moda_way's Avatar
Yes. If you don't, you won't have enough height to secure it down using the stock battery tie down bracket. Unless you're like JTso and have access to heavy duty aluminum and a cutter, just use that tray.
Old Apr 14, 2007 | 10:18 AM
  #53
visuelz's Avatar
East Coast Crew
DONE!
Old Jun 7, 2007 | 09:06 PM
  #54
visuelz's Avatar
East Coast Crew
Hmm...the problem seems to have came back. The car starts and there's a dying sound but since it sounds like the engine is running, I release the key. The engine then dies. What the heck is going on? Do you guys think it's the spark plugs?
Old Aug 4, 2007 | 08:39 PM
  #55
vthree's Avatar
2006 ASM tsx
did you ever solve this?
Old Aug 4, 2007 | 10:06 PM
  #56
visuelz's Avatar
East Coast Crew
Not really. That's because it seems like the warm weather is allowing to start up better. The car still starts horribly once in a blue moon.
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
obert
Dec 14, 2015 11:36 PM
PortlandRL
Sep 14, 2015 12:01 PM
