"B1 Service Due" Light
Old Feb 17, 2010 | 11:17 AM
newbert's Avatar
My 2006 TSX's Maintenance Minder shows the "B1 Service Due Soon" message.
I plan to perform taking the required service items myself, rather than bring it to Acura. How do I reset the maintenance minder so the message doesn't display?
Thanks!
Old Feb 17, 2010 | 10:30 PM
Chelsea John's Avatar
Something like this:
With the engine off hold down the button on the left side of the gauges...(same one to reset mileage) and while pushing in start the engine and continue to hold for 10 seconds.
Old Feb 18, 2010 | 07:26 AM
Nogard13's Avatar
If I'm not mistaken, you hit the select button until the oil percentage is showing (with the key in the ON position, but the car turned off). You then hold down the select button for 10 seconds and it goes away.
Old Feb 18, 2010 | 07:46 PM
Simba91102's Avatar
Old Guy
Originally Posted by newbert
my 2006 tsx's maintenance minder shows the "b1 service due soon" message.
I plan to perform taking the required service items myself, rather than bring it to acura. How do i reset the maintenance minder so the message doesn't display?
Thanks!
rtfom
Old Feb 19, 2010 | 10:33 PM
budget_spec's Avatar
6th Gear
lol symbol b means oil and filter change 1 means rotate.
nogard your close but after holding it for a few seconds it will ask you if you want to reset then select reset. first time it did it I screwed up and had to start all over lol
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
oyayjoe
Jan 1, 2019 10:17 PM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
redsox68
Sep 16, 2015 06:18 PM
