Alignment
Old May 8, 2004 | 09:39 PM
tyre's Avatar
Question Alignment
Hi,
I just got my new TSX and I find it pulls to the left when I'm driving at highway speeds. The dealer has told me nothing's wrong with it but I still feel the car pulling left.
Does anyone else have a similar problem?
Steve - Toronto
Old May 9, 2004 | 02:15 AM
Dan Martin's Avatar
Photography Nerd
Try rotating your tires to see if that makes any difference.
Old May 9, 2004 | 02:21 AM
slo007's Avatar
Master in Science
Re: Alignment
I have the same problem. Just had the tires rotated at 10,000 miles. Still the same. It's almost 10 degrees off at 80mph, going straight down the highway.
I think the alignment is off. I'll have it checked at the 15K oil change.
Old May 9, 2004 | 02:25 AM
Dan Martin's Avatar
Photography Nerd
10 degrees
I hope you mean that you have to turn the wheel an extra 10 degrees because if your track was out of alignment by 10 degrees it would be practically undrivable.
Old May 11, 2004 | 10:45 AM
vollum's Avatar
You might want to check out some of my posts in the "recieved a defective TSX" thread
Old May 11, 2004 | 11:00 AM
dabuda's Avatar
i had a alignment problem when i picked up my TSX as well...basically they said the hooks to hold the TSX down during transport prolly screwed up the alignment. therefore, it was covered under warranty and they realigned it for free
Old May 11, 2004 | 05:14 PM
slo007's Avatar
Master in Science
Originally posted by Dan Martin
10 degrees
That's right. The steering wheel is visually off by as much as 10 degrees. It's annoying to look down when going straight and see me holding the holding like I was in a wide turn.
Of course, when there's wind, it looks even worst.
Old May 11, 2004 | 07:34 PM
ron's Avatar
ron
Check the tire pressure and use a couple of different guages. Our TSX from the dealer had 50psi in one rear tire, 48.5psi in the other rear tire, and over 45psi on both front tires. The Michelin tires have a max inflation pressure of 41psi and the door label states the front tires should have 32psi and the rear tires 30psi. I was truly amazed when I checked the pressure and found it that far out of spec.
Old May 11, 2004 | 10:12 PM
tyre's Avatar
Thanks everyone for the great info. I'm sure glad I got a TSX rather than an A4. Those cars have TONS of problems!
Old May 11, 2004 | 10:16 PM
tyre's Avatar
Just to further describe my problem.
When I drive on a very straight portion of the highway, I cannot drive hands-free or the car will take off to the left. Are you able to drive hands-free and still go straight?
Old May 11, 2004 | 11:30 PM
slo007's Avatar
Master in Science
Sure, as long my steering wheel is not pointing straight...
But once the steering is fixed, it will be okay. I used to do that a lot on my Jetta. Drove my passengers crazy...
Since the 17" rims and tires on the TSX make it more sensitive to bumps, it's best to keep your hands on the steering wheel at all times. Especially when backing up!!!
Old May 12, 2004 | 09:57 AM
tsx11111's Avatar
I purchased a TSX on March 12th and told the salesperson it seemed to pull to the left. I drove the car two weeks and took it in to have the alignment checked. One of the service people drove the car with me along and told me it was normal. Today, after 7500 miles I dropped it off to have them put it on the alignment machine. We'll see if they fix it. The dealer gave me a TSX demo to drive and it is straight as an arrow down the road confirming mine is out of alignment.
I believe the TSX is the best buy for the money and love the car.
My two last were a A4 1.8T & a TT Audi's.
Old May 12, 2004 | 08:13 PM
tsx11111's Avatar
Alignment
Well I had my TSX in for alignment today after a service person had driven it (a few weeks ago) and said it was fine. They aligned it and guess what it was off, and guess what else it drives the same, pulls to the left. I have an appointment to have them do it again tomorrow and we'll see. I'm getting sick of farting around with this and it better get done right this time. I've never had this problem with any car I've ever owned.
Old May 12, 2004 | 08:53 PM
tyre's Avatar
tsx11111 - where are you located? In the US?
Thanks for the info, let me know what happens!
Old May 13, 2004 | 07:59 AM
vollum's Avatar
I've had an issue with the alignment/suspension on my TSX that has been going on now since I picked it up on March 26th. Yesterday I brought the car in to a different dealer to have the alignment checked. This dealer was able to adjust the front camber and caster on my TSX. I had been told by the dealer I bought the car from (as well as independent alignment shops in the region) that caster and camber could not be adjusted on the TSX, only the toe could be adjusted. The dealer I brought it to yesterday said they could also adjust front caster and camber but not rear camber. I don't know how the second dealer was able to adjust camber and caster on the front (the fact that you can adjust them and how to adjust them is not described in the Acura Service Manual). Bottom line is that my TSX no longer drifts to the left and the steering wheel no longer feels skittish. You may want to try bringing your car in to a different dealer if your dealer is unable to correct the problem.
Old May 13, 2004 | 05:26 PM
tsx11111's Avatar
Just got my TSX back from the second alignment. So far it seems to drive staight. I'm going out of town tomorrow and will see how it drives on the road. I had a chance to see literature on the new RL, pretty cool.
Old May 21, 2004 | 05:11 PM
acuratsai's Avatar
Make sure you done the alignment plus the "tire balance", it got fixed after that. dumb dearler rep told me they did balance on "one" tire and found out should be done for all four tires~!!
Old May 23, 2004 | 09:57 PM
epkim's Avatar
My car seems to curve to the left too. It only has 400 miles on it... hmm I wonder what's up. I'll probably get my tires rotated when my wheels come in.
Old May 23, 2004 | 10:49 PM
crazymaxe's Avatar
I have always used an independant alignment shop for all my vehichles. The dealers have a factory spec with a wide variance. For some reason I believe if shimming is required the dealers don't or won't go this far to fine tune every car. My TL and TSX have both gone for and required alignment since new.and both are still straight and true at 6000 - 20000 km ,. The 60 or 80 $ is worth spending.
emailnatec
29
Sep 28, 2018 04:27 PM
Jul 16, 2017 07:33 AM
Zonian22
Nov 14, 2015 01:20 PM
TxRzrBk
Sep 17, 2015 01:07 PM
