airbag trouble
3rd Gear
airbag trouble
Hey, im new to the forums and i just picked up a 04tsx...I just recently found out that if any one of my airbags is disabled, the rest wont work...I have an aftermarket steering wheel and the airbag light is on....Is there anything I can do to make the light go away so that the rest of my airbags will work..?
T.DoT P.I.M.P. lol
1 Post
That is true, once you disable the MAIN airbag (Driver steering wheel), all other airbags will NOT work. You will need to mod the airbag sensor (input) to trick the system, I have no information on that so you will need to search. One thing for sure is the "trick" does work and some members (not sure if it's this forum or others) did it without problem.
