Aiming Headlights
Aiming Headlights
Hey,
I just recieved my car back after being repaired from an accident. The repairs the body shop did came out great but the right headlight is aimed a little low. Can anyone tell me how i can adjust them. In the manuel it says take it to the acura dealer or a mechanic but i really don't want to go through that hassel. Any info on how to do it myself would be a great help.
Thanks in advance
Thanks in advance
I remember reading a thread about that here....just do a Search and I'm sure you'll find it...I think I even remember someone posting a .pdf from the Service Manual showing how to do it...
Bye TSX, hello domestic?
Originally Posted by justlooking
Hey,
Thanks in advance
Thanks in advance
really simple, just pop the hood like xizor said and youll see a black knob with a U and a D on it for adjusting the elevation of the beam. To the left of that theres a black philips head adjuster that changes it from the left to right.
![rtfm](https://acurazine.com/forums/images/smilies/rtfm.gif)
But it really is very simple, when you pop the hood you can't miss the alignment hole. Park in front of flat surface (garage wall, etc) and point the right headlight just slightl higher than the left...
Originally Posted by tehCOW
from the factory, the left headlight is set lower than the right headlight so as not to blind oncoming traffic.
Originally Posted by xizor
actually its not the left headlight, the cutoff on both headlights which is lower on the left part of the light
Originally Posted by patch
So Euro-R headlights can't be aimed to match OEM headlights?
Tech
In the USA, the left driverside headlight is aimed lower and towards the middle of the car, while the passengerside headlight is aimed straight ahead.
It will look somthing like this: //// ||||
Overseas right hand drive cars are the very opposite, however they CAN be reaimed to US Specs.
The best way to reaim headlights is to find a shop with a headlight aim machine. Any shop that provide State Inspections should have one.
I make a living working on cars, what do you mean I am wrong? ![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Tech
I still dont get what you're trying to say.....the cutoff on any US car is always lower on the driversside headlight. When you reaim your headlights, the cutoff will change.
If you're talking about the angle of the cuttoff, meaning they're not straight across, rather they're more at an incline/ decline angle, thats just how the projectors are made.
Not trying to flame you nor am I saying you're wrong, but I do know what I am talking about.
do you know if that's true for HIDs? I can understand that halogen headlights are aimed differently.
but if you go an adjust your headlights, both are at the same level.
ASM I.S. Design FTW.
Originally Posted by brianlin87
Actually xizor, you're absolutely wrong. Re-read what TechSX is saying, the cutoff point can be adjusted and thus the headlights CAN be adjusted to spec.
hoewver, you CANNOT adjust the headlights up and down to fix the reverse cutoff of the JDM lights. if you believe this to be the case, go out and test your own to see.
Tech
if you are saying you can take the cutoff off the headlight and flip it for the JDM ones, then I can believe that. isn't the cutoff sealed inside the headlight though?
What do you mean by flipping the cutoff? All you do is adjust the projector unit up/down and side to side, and the cuttoff will move with the projector. This is how you aim the headlights. If I wanted to, I could adjust my US headlights to JDM spec....but I wont go that far just to prove my point.
Tech
Please believe what you want to believe.....I give up
![Surrender](https://acurazine.com/forums/images/smilies/surrender.gif)
![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
AmplifiedDetails
09-24-2015 02:55 PM
