Acura TSX 2007 Issues
Old 04-05-2017, 07:00 AM
Tare's Avatar
Please i have an acura tsx 2007 and the following issues are being experienced:
1) Rough idle - I have gotten my mounts checked and they are okay, but when im at a traffic light or in traffic, the engine vibrates when on drive and reduces when on neutral or park.
2) When i start the car, and i press the acceleration when the car is on Park, i dont get any response until i put it off and back on, then i get a full response.
3) My fuel economy is not so good, its not very bad but its not very good either.
Please can i get suggestions to solve these problems?
my email is tareoguns@outlook.com
Old 04-14-2017, 10:39 AM
TexasHonda's Avatar
Is check engine light on? If yes, get codes and post them.
good luck
Old 04-25-2017, 02:38 PM
7th Gear
stoskus's Avatar
Sorry to be the bearer of bad news, it is your AT clutches going bad. check the color of the At fluid. if it is brownish like motor oil, then it is from burned-up clutch material. normal fluid must be cherry red and transparent. the debry is clogging the valve body and that is why you get no or delayed response while shifting. try to flush the fluid, it will take some of the bad stuff out. but in the worst case you arte looking for tranny rebuild. you can do it yourself if you have garage and basic tools. if not, then try to get tranny from wrecked TSX and replace.
Steven Chan
06-02-2024 02:01 PM
ImBroke
04-11-2017 05:40 PM
losiglow
10-19-2016 02:13 PM
Robert Rodriguez
New Member Introductions
10-07-2016 09:03 PM
Joel108
10-06-2016 11:23 AM
Quick Reply: Acura TSX 2007 Issues
