Acura ServiceNews Bulletins
Old 07-28-2008, 05:20 PM
  #41
jlukja's Avatar
June 08
Link for June 08 has been added.
TSX owners may want to check out:
- New 12mm x 1.25 Pitch Compression Gauge Adapter Available (pg. 1)
- Which Multiple B-CAN-Related DTC Do I Troubleshoot First (pg. 1)
- The Best Way To Unwrap A New Oil Filter (pg. 1)
- AIRBAG OFF Indicator Turns On and Off With Front Seat Occupied (pg. 2)
- Got DTC P2422? Check For Blockage in EVAP Canister Vent System (pg. 2)
Old 07-28-2008, 05:38 PM
  #42
mrgold35
mrgold35's Avatar
Received 1,518 Likes on 1,184 Posts
I saw in the May 2006 bulletin, page 4, about the Acura music link not available for 06 TSX until some "system conflict" issues were resolved. Does any one know if the conflict was resolved (its been +2 years) and can we use the music link for 06 TSX with Navi?
Old 08-19-2008, 09:23 AM
  #43
jlukja's Avatar
July 08 added
Added link to July 2008 edition.
Items that may be of interest to TSX owners:
- New Microphone Assembly Improves Voice Command Recognition (pg. 1)
- Use Torque Screwdriver to Tighten TPMS Valve Stem Nuts to Spec (pg. 1)
- Why Do Incandescent Lightbulbs Fail? (pg. 2)
- Audio Unit, HandsFreeLink, and HomeLink wont work. (pg. 3)
- Excessive Parasitic Draw? Check if the B-CAN System is Awake (pg. 4)
Old 12-09-2008, 10:14 AM
  #44
jlukja's Avatar
Link added for Aug. and Sept. 08
Links for August and September 2008 have been added.
Of possible interest to TSX owners:
August 2008
- Flat Rate Gets a Face Lift! (pg. 5)
September 2008
- Interior Water Leak? Try This Tip To Pinpoint The Source. (pg. 3)
- Window Glass Damage From Hydroflouric Acid. (pg. 4)
Old 12-09-2008, 10:36 AM
  #45
jlukja's Avatar
Link to October 2008 added
Added link to October 2008 edition.
- Name That Noise From This Handy Chart (pg. 1)
- Can't Find That XM ID? Just View it Electronically (pg. 3)
- That Noise From the Drive Belt Idler Pulley May Just Be Normal (pg. 4)
- Don't Use Expanding Foam to Eliminate Body Creaks (pg. 6)
- Body Creaks: Some Handy Tips to Find and Eliminate Them (pg. 7)
Old 12-09-2008, 10:42 AM
  #46
jlukja's Avatar
Link to November 2008 added
Added link to November 2008 edition.
- Removing Aged Wrap Guard or Clear Guard (pg. 1)
- Soiled Leather Seats? Clean Them First Before Thinking Replacement (pg. 1)
- Fuel Cap Message On? The Fuel Fill Cap is Loose or Missing (pg. 2)
- Use New Deburring Tool When Installing Accessory Trunk Spoiler (pg. 3)
Old 01-13-2009, 12:10 PM
  #47
jlukja's Avatar
Link added for December 2008
Added link to December 2008 edition.
- Transferring Personal Data to a New Navi Unit: A Few Facts and FAQs (pg. 1)
- Multiple Electric Problems After Body, Engine, or Trans Work (pg. 3)
(This one has to do with finding and fixing poor grounding)
Old 05-29-2009, 10:02 AM
  #48
jlukja's Avatar
JTso, thanks for keeping these updated while I've been away.
Old 07-15-2009, 09:44 PM
  #49
JTso's Avatar
No problem. I've been a little busy myself.
Old 01-30-2010, 01:42 PM
  #50
JTso's Avatar
Just updated the remaining TSBs for 2009.
Old 08-04-2010, 09:37 PM
  #51
limeybstrd's Avatar
None of the original links work?
Old 08-19-2010, 12:32 PM
  #52
JTso's Avatar
It's fixed now.
Old 10-02-2010, 12:27 PM
  #53
orbitup's Avatar
This is what I see when I click a link
You are not authorized to view the content on this page.
If you believe you have received this message in error, please contact the Support Center.
Please go back or return to the home page.
Old 10-06-2010, 01:15 PM
  #54
carlrob20's Avatar
I'm having the same problem. I'm trying to reach the May 2007 link but it doesn't work for any of them.
Old 10-06-2010, 01:45 PM
  #55
Administrator
Ron A's Avatar
Received 1,004 Likes on 574 Posts
I added a note at the top of the first post which will explain why you can't open any of the bulletins.
Old 02-19-2013, 09:56 AM
  #56
CL9 Jon's Avatar
Anyone have the headlight condensation TSB
BobbyGraham388
10-22-2015 05:05 PM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
sockr1
10-01-2015 01:31 AM
asahrts
09-04-2015 05:55 PM
LAMike240
09-03-2015 04:35 PM
Quick Reply: Acura ServiceNews Bulletins
