AC troubleshooting
Old Jun 12, 2017 | 08:56 AM
Lone Starr's Avatar
'06 TSX 6MT
AC troubleshooting
I noticed yesterday that my AC wasn't working anymore on my '06 TSX 6MT (it was the first really hot day in a while).
I've read enough threads to figure out that there's a lot I can do to make things worse, but not sure exactly where to start.
Probably unrelated, but I've recently (in the past few months) changed the accessory belt and battery.
Any advice is greatly appreciated- TIA
Old Jun 13, 2017 | 08:22 AM
TexasHonda's Avatar
First step is get a set of gauges and check system pressure. A leak or slow leak down (13 yrs) is most likely but start w/ system pressure.
good luck
Old Jun 13, 2017 | 08:46 AM
Lone Starr's Avatar
'06 TSX 6MT
thanks. I got a refill kit from home depot, and the low side pressure was off the scale, which in retrospect makes sense since the system has equalized.
I dug out the FSM from the basement and went to town last night with the diagnostic modes and a multimeter.
I now know the issue is with the clutch not engaging (ruled out fuses, relays, sensors, and seized compressor) - I'm hoping it's a grounding problem, but I'm not optimistic.
I haven't found a clutch/coil set cheaper than a complete compressor kit, even if it's just the clutch, am I better off replacing the whole compressor at this point?
Old Jun 13, 2017 | 09:19 AM
TexasHonda's Avatar
So you've confirmed absence of 12V at the compressor connector?
Next step is to check relay contacts for power and ground signal from ECM/PCM. See attached wiring diagram.
good luck
Old Jun 13, 2017 | 01:44 PM
Lone Starr's Avatar
'06 TSX 6MT
As I suspected, it's the solenoid- i checked every input, switch, relay, sensor and wire to the compressor connector (including the thermal protection switch on the compressor itself).
As a final check, I jumpered the thermal
I measured infinite resistance across the coil itself, so either the wire to the coil is bad (i don't see any issues on visual inspection) or the coil itself is shot.
Old Jun 13, 2017 | 02:45 PM
Lone Starr's Avatar
'06 TSX 6MT
Old Jun 13, 2017 | 03:21 PM
TexasHonda's Avatar
Did you every confirm 12V at the compressor clutch connector? Measuring resistance of clutch coil is fine, but easy to get an incorrect reading.
good luck
Old Jun 13, 2017 | 04:32 PM
Lone Starr's Avatar
'06 TSX 6MT
yeah, when I jumpered the thermal switch pins in the connector, i saw 14V on the middle pin.
the car's 11 years old (almost half of that un-garaged in Boston), so it's not surprising that the coil went.
I suspect the clutch failing saved me from the infamous black death, so I'm going to just replace the whole compressor.
