2007 TSX Blinker
Old Dec 8, 2021 | 06:13 PM
Knagy1125's Avatar
2007 TSX Blinker
my acura blinker stopped working. just the left, the right works fine. when i put hazards on, left still doesnt work, and right is fine.
bulbs checked, relay replaced (and expensive non returnable part). ideas?
Old Dec 8, 2021 | 09:22 PM
How did you “check” the bulb? Have you tried just replacing it
Old Dec 8, 2021 | 09:35 PM
Knagy1125's Avatar
Yea check for broken inside and replaced front and back as well. The inside bash doesn’t light up either
Old Dec 10, 2021 | 04:24 PM
SpiderX1016's Avatar
I would replace the Turn Signal/Hazard Relay located at Driver's Under-Dash Fuse Box. Be careful with the tabs on the side, it's a little tricky to remove and they break easy.
kennethklee
May 27, 2006 07:53 PM
