2005 TSX Front Vibration
Hi Everyone,
For the past 2 months or so I have been noticing a vibration coming from the front of the car. The car has not been in any accidents. It has 130K miles on it, but its all highway miles and i take good care of it. I put all new Brake Pads & Rotors about a year ago. Got 4 new tires. The car was running great. Now when im getting on the highway, once i hit 60 it starts to vibrate a little. Then once i get over 65-66mph, the vibration stops. When im coming off the highway, if i just coast and let the car get to about 60MPH and then hit the brake i get no vibration. If i dont coast, and hit the brakes going over 65-66mph, it will vibrate until it hits about 60. Now the tires were aligned when i put them on. I havent hit anything. What could possibly be causing this??
Someone had mentioned a steering rod to me..? That makes sense?
I would greatly appreciate an answer ASAP just because this is really really aggravating me already.
idk if we have the same but around 60mph my car vibrates in the front. i replaced axle. have a bent wheel but vibration was there before the wheel was bent and have 4 new tires. toyo proxes. also i have eibach springs as well on stock struts. well i replaced my right axle where i thought the problem was coming from but had no luck. now i'm going to check my motor mounts. i wont have time till this weekend but i'll let you know what i come up with. bad motor mounts can transfer vibration to the car at different speeds.
handsom-hustla
11-13-2015 05:04 PM
nuldabz
09-03-2015 05:49 PM
