04 TSX MT Trans?
04 TSX MT Trans?
I have an 04 MT TSX with 120k miles and I need to either replace the transmission or have it rebuilt, I think replacing it would be less expensive. My question is would a second gen TSX transmission fit my 04 or do I have to buy a 04-05 trans.
There may be a difference. When I checked car-part. com, they only list 04-05 as donors. I've found their cross-reference to be pretty accurate. Used trans are pretty expensive; $900-$1500 bucks. Pretty low supply also.
Rebuilding may be a viable option.
good luck
good luck
What symptoms are you having that make you think that the transmission needs replacing? Slow, awkward, missed shifts? Excessive effort trying to get it into a gear? Grinding when shifting? I had my 06 clutch replaced at 120,000 miles, and the transmission works better than it ever did.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
