04 headlight problem
Old Nov 15, 2007 | 09:03 PM
sjsamuel's Avatar
3rd Gear
Hello everyone...just go a hold of a 04 TSX 6spd /Navi used...didn't realize till later that the driver side low beam is out...ordere some HID bulbs and replaced it no luck...Then realized that the fuse was blown...should have checked that first <---STUPID. Anyway...the bad problem...light still does not work. High beam is fine...bulb switched to other side works fine....Any help would be great....THANKS ahead of time..
Old Nov 15, 2007 | 09:36 PM
Mskierki's Avatar
Welcome to the forum, use the search function it will be very useful. Also check out the DIY section.
In the interim:
https://acurazine.com/forums/showthr...dlight+ballast
Old Nov 16, 2007 | 12:28 PM
LoveMyTL-S's Avatar
I don't know much about the HID's but welcome to the forum.
Old Nov 16, 2007 | 12:58 PM
luder917's Avatar
SSM FTW
check your ballast
Old Nov 17, 2007 | 10:07 AM
OoKrnBoi0331oO's Avatar
i dont know, if it's the fuse, usually both sides go out. check your wiring, maybe one of your wires got messed up.
Old Nov 17, 2007 | 01:58 PM
sjsamuel's Avatar
3rd Gear
Thanks for all the suggestions and the welcome guys....for right now, after reading about the recall and noticing moisture in that same headlight we are taking it to Acura to hopefully fix that first. After some research and your help I think it is the ballast...but WOW those things are high.
Old Nov 26, 2007 | 03:43 AM
blaqtsx's Avatar
I have the same problem with one of my headlights, and I think it is the ballast. Does anyone know how much a ballast would cost? and also how much they would charge to install it? thanks.
Old Nov 26, 2007 | 06:57 AM
HoRRo's Avatar
iVTEC no koe
Taken from https://acurazine.com/forums/showthr...983#post743983
If it's #9 (Part# 33119-SCC-003 CONTROL UNIT ASSY.) in the above pic, should be about $172
Old Nov 26, 2007 | 02:21 PM
liteglow's Avatar
You can find cheap ballast on eBay !
(and if you dont care so much, you can replace it with a regular OEM hid ballast from another car.. but then you need to manually connect the wires)
my tip...
tman570
Jun 11, 2019 07:56 AM
TLrascal
Aug 3, 2018 11:00 PM
MistaWet
Sep 15, 2015 08:26 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
