02 sensor cel on t1r test pipe
Hello, I just bought a T1R test pipe on my car and installed it at shop then I noticed that engine light was on and called "maintenance required". I wonder if it caused from test pipe with sensor cel? I know that I have read the comment but can't remember. Can you help me out with this info?
Thanks,
George
Thanks,
George
The maintenance reminder is not the result of an engine problem. It's telling you that service is required (oil change or more) based on the miles and your driving habits. It is unrelated to the test pipe though it is likely you will need to install an anti-fouler to trick the ECU into believing the non-existent cat is working as well as the OEM cat, which obviously it's not going to do.
How can I reset the light? I know that my car's low beam headlight had trouble after Hondata Reflash installation. After Reflash, Both side of low beam headlight was not working then I decided to disconnect the battery and connect the battery again then finally right low beam was working and left was still not working. When I drove on street and low beam headlight was a like flash and turned it off. I dont know if engine light caused by headlight trouble or not. I am not happy with it and need to figure it out to fix it. Thanks for all info and help me out.
Where can I find anti defouler? I hope it will work out on test pipe. I know TSX owner has T1R test pipe out there and need their comments.
johnpancakes014
09-27-2015 12:58 PM
