Weekend Project - Painted Engine Bay
boost owns
I had some time on my hands on Saturday afternoon and decided to match my sparkplug cover and intake manifold cover to my Cusco bar endlinks. I also painted my dipstick black to avoid shelling out $30 for a JDM dipstick that isn't even functional in the K24. I think it came out pretty well... but I'll let the Internet be the judge.
The paint isn't as light as it looks in this picture, the lighting is throwing it off. It is a much closer match to the Cusco parts in person.
Received 3,860 Likes
haha wow not what I wanted to see. I was excited for a second and thought you went a crazy extra mile and went two tone with your engine bay actually. darn so much for my excitement.
still looks good though.
boost owns
LOL, maybe I mis-titled this thread, I was looking for brevity, didn't want to say "Painted Sparkplug and Intake Manifold Covers" although I guess I should.
Two-toned engine bay would be sick though. Maybe if I'm ever showing, haha.
boost owns
Thanks all.
I was at Wal-Mart and saw Krylon's line of "XMetals" paint. The blue looked strikingly similar to Cusco blue so I picked up a can. They also had metallic purple, green, red, and gold that I remember.
As for the dipstick, I just picked a random can of heat-resistant black spraypaint. I sanded the dipstick lightly and gave it two or three coats. It came out a flat black, after which I clearcoated it to get it to shine a little.
boost owns
I sanded the sparkplug cover/intake manifold cover with 200 grit paper to just lightly rough the surface up. Then I applied Krylon XMetals Converter (which is primer that you use if you're painting plastic), then four coats of the blue XMetals paint. I did not clearcoat. In retrospect it wouldn't have hurt to, but I don't think these parts are going to see much in the way of rock chips/general damage so I think it'll be OK.
Also, the clearcoat I used on the dipstick actually came out really thick and globby (you can't tell from a distance in my picture) and I was reluctant to risk doing that to my beautiful blue paintjob.
boost owns
Originally Posted by lcrazyaznl
Shouldn't we use high temp paint as well ?
looks great by the way i was going to paint mine black with the nuespeed bar.
boost owns
Well I made at least ONE mistake apparently.
I forgot to glue the "A" on the sparkplug cover back on. When I popped my hood this evening the Goddamn thing had disappeared. I got a flashlight and poked around the engine bay and didn't see it anywhere so I assume it's long gone.
For those who don't know, it's secured to the sparkplug cover by two holes, similar to the A in back of our cars. I guess that wasn't enough to hold it on the cover during travel. Now I have two holes in it and it looks naked.
If anyone can help me find either the A by itself or the whole sparkplug cover, I would really appreciate it. I've scoured acuraoemparts.com and I can't find either.
This sucks!
This sucks!
boost owns
I got the two covers done with one can of blue (almost finished it) and one can of primer. I'd buy two of the color in case you screw up and have to re-do anything (it could happen if you haven't spraypainted much before, trust me!) besides its fairly cheap.
私はより良い
This sucks!
This sucks!
his windshield was cracked by a "flying acura logo"?!?!
boost owns
Originally Posted by LoveMyTSX
Nice........and what kind of primer did you use? I may do this mod this week.
Don't forget the 200grit sandpaper, and spend as much time as you can masking the "iVTEC" plate on the intake manifold cover with painter's tape. As I'm sure you know after your great caliper job, it's 90% prepwork, 10% painting! Also key to note: either remove the masking tape as soon as you finish painting, or, score the edge of the tape with a razorblade before peeling it up. I didn't do this the first time around and I ripped up some of the blue paint, necessitating a re-spray.
To Cybereclipse: I don't even know for sure if it fell out on the freeway or even if it left my car, it might be somewhere down on my splashguard where I can't see it. But it would make for an awkward call to Geico, that's for sure.
To HONgDA: thanks for the offer, if I ever screw this one up I'll keep you in mind! Haha.
boost owns
It has two prongs going through holes to the back of the sparkplug cover. The prongs are secured by clips. From the looks of the clips, they were designed to be put on once and never taken off. So I ended up snapping the prongs off with pliers and just pulling the emblem off. That method leaves you with two little stubs on the "A" to put back in the holes, and if you put some crazy glue on the stubs it should hold fine. I just forgot the glue part.
Okay, today I got all the supplies and did this mod.... Took about 2 hours, taking my time of course. Here's a quick DIY:
Bought the XMetals Blue and primer. You will also need painters tape, super glue, xacto knife or something sharp to cut with, a couple of rags, 10mm socket/wrench and 220 grit sand paper.
Use a 10mm socket to remove the covers. They come off pretty easily. I noticed it was dirty under them and used a wet rag to clean it. Also, used another clean wet rag to clean both covers really good. Prep is most of the work and helps with the finished product. You can see the dirt that was under the Acura logo on the back cover.
After cleaning the covers I took the Acura logo off. When removing the logo you have to break it off. I just used needle nose pliars to pull the back fasteners off. And a flat tip screw driver to carefully pry the logo off. It's only plastic.
I sanded both with the 220 grit sandpaper. I just went over it lightly. I then put down some newspapers on the garage floor. Spread them out well in case of overspray. I had an old metal lamp frame and layed it on the paper. I put the covers on it to spray them. I sprayed the back cover first with the primer.
While the back cover was drying, I took the front cover and using the painters tape covered the I-Vtec logo in the middle. I used a sparp cutter to score it.
After scoring I primed the front cover. Only one good coat on each cover.
Next I sprayed both covers with the XMetals blue, giving them 3 coats each.
Here is the finished product. It was almost dark when I took these pictures. I didn't paint the dip stick handle, but I might do that later.
I used super glue to glue the logo back onto the cover. I noticed when I put the logo back on it did kinda click in. So between the glue and it clicking in, I think it's on pretty good.
All in all I think it came out pretty good. The op of this thread used the XMetals converter. I used regular primer. His results may be a little different than mine and his may have more sparkle to it. Hope this helps anyone that may be considering doing this mod.
boost owns
Looks good man. Thanks for the pictorial DIY. I think you got a deeper blue than me due to using normal primer. As for the logo, between super glue and the two stubs clicking into the holes you'll be fine. My replacement logo should arrive Wednesday.
boost owns
That's funny, there really wasn't that much dirt under my logo. But then again your whole engine bay looks a lot dirtier than mine too, so maybe that's it. Get thee some engine bay cleaner, man! Stat!
Originally Posted by vthree
yall could do the fuse box cover too =)
heheh looks goood. i'm going with the black/silver theme in the engine bay.. all i had to do was buy an element cover
detailersdomain
Wash & Wax
09-03-2015 10:56 PM
