marketman's CG with BBS RG-Rs and Mugen!
Received 3,847 Likes
I wish I only could afford the mugen full bumper and kit, someday my car will have it probably not till I am out of college.
Automobile Aficionado
Originally Posted by xizor
you need a camber kit man! interesting you can see the CAI filter through the hole in the bumper. looks pretty good!
looks good
These are old pics from the day I installed the Eibach pro kit and the BBS's(50mm offset-18lbs. per wheel without tire)/Goodyear 245/40/18 F1G3's and Engals camber kit - took it to alignment shop the next day. Since then I have painted the calipers in black urethane. put drilled/slotted Rotora rotors on(which I installed, measured braking sweep area, and then taped off and powdercoated hub, disc face and vents so I would have no rust slinging around or showing on rotors/wheels) , Axis ultimate pads, Comptech rear sway bar, Hondata reflash(awsome!). The Mugen front end gets more compliments than anything (even though we had to paint it 6 times to get a perfect match on the paint). It may cost a lot but urethane is so much better/durable than fiberglass. I need to take some updated photos and post.
Thanks Lanny M for posting the pics!!
Are you sure those tires are 245-40-18s? From the side profile, it looks pretty thin - more like 225 or 235-40-18s.
If they are 245, have you had any rubbing issues w/ them so far?
Iakonafuji
09-21-2015 02:39 PM
