Blue LED replacement for Doors/Dome
#81
Originally posted by moda_way
Here are the bulbs you'll need from Superbright leds
(you'll need to count to make sure)
Red 7443s (I think 2)
White 7443 (which you'll mod into a 7440 by pushing two wires around) (2)
Red 168/194 bulbs (I think 4)
White 168/194 bulbs (Use these for your license plate) (2)
In every case, get the largest amount of LEDs per bulb, so on the 168/194 bulbs, you'll be getting 6LED configs.
I was wondering if you saw these lights:
http://autolumination.com/3157_3156.htm
the matrix 25- LED lights. I know they are not the same code as the ones you mentioned but they also come in wedge and was wondering if you know that if it could fit in the rear lights since they are also wedge based. These look nice. Anybody have any thoughts? Thanks!
#82
'Insert witty text here'
So is this the right bulb to buy from superbrightleds.com for the doors?
WLED-B4 Blue LED bulb
12VDC Blue 4-LED Wedge Base Bulb (194/168 type)
or this one?
WLED-6 LED bulb
12 VDC 6-LED Wedge Base bulb (194/168 type)
Our brightest bulb of this type
Non Polarized
Select White, Blue or Red LED color
$ 2.99
or this one?
WLED-6 LED bulb
Non Polarized
$ 2.99
#83
I spend 2 much time here
for some reason i cannot get led lights to work properly in my front dome lights. when i install them they don't turnoff. but when tried xenon bulbs in there they workedfine. also led bulbs work fine in my rear domelight. can anyone explain this phenomenom?
#84
or this one?
WLED-6 LED bulb
Non Polarized
$ 2.99
or this one?
WLED-6 LED bulb
Non Polarized
$ 2.99
T13-B6 Blue LED bulb
12VDC Blue 6-LED Wedge Base bulb
#86
So, do you like...stuff?
#87
Originally posted by RogerPodacter
you know what this happened to me as well. But i switched the front dome lights by putting the left in right, and right in left. that fixed the problem, although i have no idea how or why it would matter which side the lights are on. hope that works for you.
#89
Don't listen to me.
If you put the lights in one way they don't work correctly. All you have to do is turn them around. That's what worked for me.
and bondgirl is correct the...
measure 1 1/8 long by 1/2 inch maximum diameter (194/168 type)
$ 2.99
...is the correct bulb.
$ 2.99
#92
i ordered the exact model number from superbright leds as posted in this topic above for the door lights, yet they dont seem to work. when i put the stock ones back in they work fine. is there some special trick to installing the bulb or does it have to be inserted in a special way.
#93
Don't listen to me.
#94
Thanks for all the pointers guys.
I just ordered Xenon for the Domes and also Blue LEDs for the domes and doors. Still undecided so I will try both, they are cheap enough. Let you know when I receive and install. Will try to get some pics too!
Before I install though, I was looking at the rear dome, and just curious how you open this fixture as I did not see the tabs holding the lense?
#97
Don't listen to me.
Originally posted by KingV
I just got my blue LEDs. Put in the ones above the passenger and driver's seats. So far I'm undecided. Do all the lenses just pop out with a screwdriver?
#98
2018 TLX A-SPEC
or this one?
WLED-6 LED bulb
Non Polarized
$ 2.99
or this one?
WLED-6 LED bulb
Non Polarized
$ 2.99
Jay are you realy going to put these in your car? RICE!
#99
after popping my dome light covers off and putting them back on a couple times one of them got a little play in it. Not enough that you would ever notice unless you have some major bass in your car from subwoofers. That was an annoying rattle boy, let me tell ya. But after i replaced it with a new one it was tight as can be and no rattles.
#100
Could someone give me the sizes I need or recomendations. I want to replace all the bulbs in the interior to super white. I know I need the 31mm festoon xenons for the front domes, but I was wondering what sizes I would need for the side and rear domes. Thanks.
#102
wow.... i forgot about this thread. lol. i had a post in the first page saying my domes have burnt out. and.... months later, i still dont have interior lights..
im definately gonna get into action now. i have the indigo blue car.
hwo do you think some pure white dome lights, the blue door lights would look. or is it better to stick with just white or just blue?
#103
Don't listen to me.
BlkTxAcuraTypeS
10-18-2015 08:05 PM
