yet another brake question
ATCer
If I am correct, the dimensions of the front rotors (stock) are 300mm x 28mm
rear are 260mm x 9mm
With that being true, as long as I find a rotor in the same dimension, with a 5x114.3 bolt setup, a rotor should be interchangeable, correct? Or is there more to replacement rotors?
I ask this on my quest of still obtaining different replacement rotors. I have found rear rotors of the same dimensions from an EK9 (rear) and same front as a CL1, and RA6 thru 9 (whatever type car that is).![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
Any help would be appreciated.
Any help would be appreciated.![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
ATCer
Originally Posted by vwong
You should also check the dimension of the depth of the "hat" (or the hub). If they're not the same, you may run into problem with the rotor interfering with the caliper.
Just out of curiosity, how would I find dimensions of the hat? What numbers would I be looking for... just an example if you can think of one.
I researched a bit more for the CL1 rotors, and several japanese companies sell rotors for the CL1 having the same part number for the CL7. From my understanding, the brakes from the CL7 and CL9 are the same.
ATCer
OK, CL1 and CL7 are the same (CL7/8/9 also same)
Next question, which google has given no help for. Does anyone know where to find part numbers for Honda Japan OEM equipment. Specifically EK9R rear rotors?
Just get a set of brembos or even the powerslots. I use the powerslots on my 4runner currently and they work pretty well. Really good quality rotor. Haven't used brembos before but have heard nothing but good from them.
When it comes to the replacements for the TSX, any rotor that will fit the RSX-S will fit our car. Same components (just different mounting point for the calipers). For instance the Spoon rotors will fit (though the part for the RSX is the S2K rotor...same fitment too). Stoptechs are okay, they're just pricy for what you get. That's what we used on the DAL Motorsports grand am cup NSX.
I got StopTech and Rotora now, but looking for something more JDM or so to say. ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
ATCer
Just my humble opinion, you're wasting the money trying to find JDM rotors. Brembo blanks or some OEM replacements are good enough.
Brembo blanks
![Thumbs Down](https://acurazine.com/forums/images/smilies/thumbsdown.gif)
As far as other replacements, I agree. I just want to keep all my parts running with the same companies, rather than mix-matching so much. Since I'm going with Project Mu lines and pads, I am gonna get their replacement slotted rotor as well. Spoon is another brand I have several pieces of, so will get their caliper.
Sounds weird, but I enjoy finding new parts and "wasting the money" redoing things on my car.
ATCer
Slotted/ cross drilled is different. I don't know what the specific company is that makes the blanks for Brembo, but it's one in the same as the OEM rotors (blanks), which are easy to warp.
Brembo is one of a few companies that puts R&D into new kits which consist of drilled or slotted rotors, StopTech being another.
StopTech offers a great BBK for the TSX. Expensive, but good.
CMF, last time I checked the Spoon's runs around 1500 for just the front set calipers. Are you getting a better price or sth? Cause for $200 you can get a complete set from Stoptech.
Originally Posted by JTso
I have installed a set of Brembo blanks for someone as the originals were shot. The Brembos were much heavier than the OEM rotors. He got them from Tirerack.
mada51589
05-03-2022 08:54 PM
