What are JTso's oilcatchcan/TBbypass ?
Hey,
i remember reading the posts when everyone started doing the 2 mods but then, and now, i didnt understand the purpose.
does anyone feel like giving me the rundown in simple term?
starting wtih oil catch can. why is it catching oil?? is it used in engine preservation or performance
and the TB bybass im far from even grasping.
thanks in advance
Cman
thanks in advance
Cman
Moderator Alumnus
JTso, I was wondering about the TB bypass: Would it be possible to put a valve that would direct the coolant either away from the TB during summer, but could divert it back into it during winter?
Kind of like on/off...
Bye TSX, hello domestic?
Yeah. That would be a viable solution for me, a lot easier than doing and un-doing the mod each spring and fall.
I'll look into it.
I'll look into it.
My Garage
I'll look into it.
I'll look into it.
Okay, I think there is a easier way to switch between bypass and normal mode with simpler components.
Parts needed:
2 - straigth fitting with build-in valve
2 - normal T fittings and some hoses
Before TB bypass
This is how the hot coolant flows through the TB heating the TB in the process.
TB bypassed with valves and T fittings
When both the valves are closed. Coolant flows through the T fittings.
Valves opened
When both valves are opened, coolant flows through the TB as well as the T fittings. This is similar to how the thermostat and coolant bypass works.
Parts needed:
Before TB bypass
Valves opened
My Garage
Awesome idea. You are the man jtso
Doesn't seem too hard to do either. I haven't looked around the TB, is there enough room around for all these extra parts? Can you give some detail on the parts needed or is this still in idea form? I'll take a trip to tomorrow and try this as long as i know exactly what valves and hose to get.
I'm assuming enough coolant would pass through the TB even though it is going through the t-fitting as well
Catch can on TSX. It's left of the windsheild washer bottle tie wrapped
to the A/C line.
I did something different and have 4 drill holes through the top
of the filter.
About 1 week of oil accumulation
to the A/C line.
of the filter.
Originally Posted by JTso
What are the holes for? Did you also remove the black gear inside? Btw, nice mounting.
I'm concerned an oil impregnated filter will not breath well so I put
4 small holes almost all the
way at the top of the filter. To be sure it doesn't restrict when the filter is saturated. I'm thinking of taking the filter all the way out.
I'm going to break the line on the block side and be sure it is pulling
well under vacuum, remember vacuum is only high at closed throttle.
At open throttle when the crankcase is pressurizing from blowby
and this thing needs to be breathing is when the intake vacuum is lower.
I'm going to make sure it is sucking with throttle open at low vacuum.
Actually, the PCV system is not functional during WOT regardless how many or how big of the holes. When that happens, blowby gases is going to travel up the oil galleys, to the valve cover, through the top vent hose, to the intake pipe and through the throttle body. That's why you will notice some oil film build-up on the throttle plate and the vent hose. This is an old problem exists for a long time, even worst in a FI setup.
Actually, the PCV system is not functional during WOT regardless how many or how big of the holes. When that happens, blowby gases is going travel up the oil galleys to the valve cover, through the top vent hose, to the intake pipe and through the throttle body. That's why you will notice some oil film build-up on the throttle plate and the vent hose. This is an old problem exists for a long time, even worst in a FI setup.
That sounds like an open system which is popular setup for FI applications. What it does is to route the valve cover vent tube to one side of the catch can. The PCV valve is completely removed and replaced by a tube and routed to the other other side of the catch can. The top of the catch can usually has a filter for venting out to the atmosphere. Basically, this method bypassed the PCV system and will not pass emission inspection in some states.
Also, you will see different ways of connecting the hoses and sometimes they are not connected correctly.
WOW, in the end. i still dont understand the oil catch can. i know its easy to just refer to the other posts but they have guys asking the same question and it doesnt get fully answered.
1) the TB bybass, from what i can see your just rerouting the tube to skip and area where itll heat up, which should be changed back for winter. maybei get that.
2) oil catch can, what is that tub that oil is getting into?? like i hear "oil gets in combustion" from which entrance? and whats that tube moving if its catching oil.
So what is the tube carrying, and why is there oil in it.
and the TB bybass is for performance, and the oil catch is for engine cleansliness? verify please
My Garage
Hey JTSO, I finally got the L fitting, had a bitch of a time finding one.
Anyway, my K&N also came in the mail today, so I will try to find time to install it this weekend. I'll do the TB mod while I have the stock intake off. Worked out perfectly.
My question to you is...are the plugs you put on the TB neccessary or are they just for a clean look?
JTso
106
02-13-2016 03:41 AM
JTso
70
04-06-2010 11:14 PM
JTso
152
05-25-2008 10:27 PM
fedlawman
21
02-23-2005 05:58 PM
