TSX LSD Possibility?
Polar Chicken
I was surfing the Temple forms and it looks like some guy installed the RSX-S LSD into a TSX with positive results. The cost is sorta steep and I would imagine that it would be a good opertunity to do a clutch/light flywheel replacment but I would be stoked for this.
What are hte group thoughts on this?
http://www.vtec.net/forums/one-messa...sage_id=472480
Received 3,860 Likes
hmmm very interesting. however I was stupid and bought an auto.
Mugen CL9
Zasker1 - I've also thought about having a LSD put in down the road, but it is a little pricey for parts and labor. I've seen that almost any LSD for the RSX or JDM Integra will fit our cars. People have said that the performance of the car will greatly improve.
hmmm very interesting. however I am mature for my age and above all this racing and shaving every hundredth of a second off the 1/4-mile so I bought an auto.
Polar Chicken
Originally Posted by Yui
I have seen that one before but I belive the RSX-S one is a little cheaper, its still 2k any way you look at it. 3k if you do a clutch and flywheel.
I did the pullys, who wants to be the first with this?
I would buy the Quaife for the RSX, or the new Civic Si if it fits. 100% lifetime guaranteed! Works great and you can use stock tranny fluid
BDI aka Booty Man
Shadowlegz also put lsd in. http://www.acura-tsx.com/forums/showthread.php?t=29463
Originally Posted by jlukja
fixed
Special-K
Originally Posted by MrHeeltoe
RSX S = Civic Si = Euro-R......but all those cars have the K20 in it. Not sure on the K24 app.
Bye TSX, hello domestic?
Originally Posted by PrecyseStylez
but the tranny is the key right? i thought they shared the same tranny just different gear ratios? but i was gonna try this out also.. i was thinking that if you get an RSX-s after market Clutch and Flywheel that i would fit on the TSX tranny but you would need that combo..is that right?
Former Sponsor
I am referring to transmissions.....I am not sure if the TSX is different or not...I can do some more research on it.
Marcus
i installed a quaiffe lsd along with the crv final drive set!
the car is a completely different animal.
a definate must for anyone cosidering tracing the tsx.
i did once before this mod and was very boring, and painfully slow through hairpins.
Former Sponsor
That sounds like a pretty cool upgrade!
Special-K
Moderator Alumnus
Originally Posted by oaksnutz
What type of performance gain do you get out of the crv final drive??
I thought the best combo was the RSX-S gearbox with the TSX final drive..
Quaife LSD
no..you woulndt need the crv final drive set for the rsx lsd to work
the crv final drive is 5.06, ive seen poeple just call it 5.1
yes..that is the part # all k series trans are the same. (except spacer for speed sensor, dont lose that!)
i also did exedy stage 2 clutch and lightwieght flywheel.
yes..ill sell you my 4.7 final drive. make me an offer
Originally Posted by Maxboost
Try a search. I remember a while back a member on here with 2004 put JDM DC5 ITR LSD onto his TSX.
He ran into some hick ups but it's working.
Originally Posted by matvey
For those of you who have installed an LSD; did you have any problems with VSA not working?
Thanks!
MBA
Thanks!
MBA
Originally Posted by k24
No problems with the VSA, the installation of the LSD will not affect it.
MBA
Mugen freak
Will this only work on a MT car? I know that the clutch type LSD only obviously works on MT, but there are many different kinds of LSD's, one of which uses a type of silicone liquid and does not attach to the clutch (http://en.wikipedia.org/wiki/Limited_slip_differential). Would any of these work on an AT?
Poser / Fanboi
An AT would not use an LSD. This is a MT thing.
Also, just because an LSD is a clutch-type does not mean that it is for MT only. It has nothing to do with the MT clutch. It just means that the LSD has clutches inside of it.
MBA
MBA
Poser / Fanboi
Originally Posted by chuson
Well, LSD is a limited slip differential... I thought AT doesn't even have a part of this will fit.
The AT has Torque Convertor, completely different stuff.
Some LSDs have clutches, but they has nothing to do with the clutch that sits between the pressure plate and the flywheel.
Responding to other statements that an LSD is only a performance option - try going up an icy hill with VSA on... the system will brake the car to a halt rather than let it spin. With an LSD, you 1) will apply torque to both wheels (and so will have a lesser chance of spinning out and 2) you have a traction control system that is non-lossy... very useful in this situation.
