TSX Dynos
#402
Originally Posted by vwong
^^^ Did you leave out some information? There is no way to have that kind of increase with the 2 mods you listed. Sorry, I have to call this a BS.
#405
Originally Posted by JTso
If he had any credibility at all, it's been long gone when he posted the same BS in the other thread. No one will take him seriously.
#407
quick question, if I get my ecu reflashed by hondata, would I be able to reflash it back to stock setting in case things go south? or for warranty related issues? do I have to send it back to them again? free of charge if any?
#408
Search on the Hondata reflash and you will find all the answers that you seek.
#409
I already have a thread going (click here to view it), but for the sake of consolidation I figured I'd post here as well...
Here are the first dyno results for a S/Ced 2006 6MT. My current engine mods are:
CT Supercharger
CT Icebox
CT Header
RT Cat
CT exhaust
The first dyno sheet is showing STD correction and smoothing of 5:
The second dyno sheet is showing uncorrected and smoothing of 0 (which means this is what I actually put down on the dyno):
I was expecting more, but I'm happy with the results - in particular, the flat torque curve .
CT Supercharger
CT Icebox
CT Header
RT Cat
CT exhaust
#411
Originally Posted by swift22
^ nice numbers however i would get yoru A/F corrected in those higher spots to get it closer to 12.5:1. Just to be on the safe side.
#412
Sorry as I haven't reasearched into what managment the CT S/C uses? I assume its the hondata s/c reflash? Your a/f are pretty lean, Id be afraid of a bad tank of gas, or burning up a piston...I wonder if the management was developed on a stock motor with no I/H/E? Adding those would deffinitly lean out the tune..
#413
#414
luvs redheads!
I am a big fan of getting the most MPG I can but being safe. Alot of guys run richer to prevent detonation etc and to place it "safe". However the best combustion or burn is at 12.5:1 and I was being conservative. At any rate you have some tuning to do.
#415
CT Supercharger
CT Icebox
CT Header
RT Cat
CT exhaust
CT Supercharger
CT Icebox
CT Header
RT Cat
CT exhaust
#417
Time to Climb
info/suggestions needed:
i'm set to dyno for the first time this sunday at the crown honda meet in charlotte and need your input:
1) any prep work required of me?
2) as far as results go, i guess i need to know the type of dyno i'm rolling on and whether or not my results have been sae corrected?
3) anything else i should be aware of?
my pr2 gaskets, spacer, and img will be installed on saturday afternoon with the help of fellow AZiner, chill_dog. i'm hoping to reduce heatsoak and get consistant numbers from the 3 runs (only $40)!
thanks,
vinny
thanks,
vinny
#418
thanks,
vinny
thanks,
vinny
No prep work necessary. Just make sure the guy performing the dyno runs remembers to turn off VSA, otherwise it won't work (VSA prohibits acceleration if the rear wheels aren't spinning).
What numbers are you hoping to hit?
#419
thanks,
vinny
thanks,
vinny
Prep works
1. check oil level, change oil and filter if necessary.
2. fill the tank with premium fuel
3. check tire pressure as it affects tire/roller contact (depending on type of dyno)
4. bring an obd2 scan tool if possible to monitor intake air temp, coolant temp to ensure each run is tested under the same condition.
5. bring a floppy or usb drive to store the final run files
6. arrive at the dyno early to allow time to cool down before the runs (heat soak affects the actual results
On the dyno
1. use wideband o2 hookup
2. don't touch the steering wheel during the runs!!!
3. ask the operator to start recording the runs at very low rpm ~ 2000 and use sae correction.
4. turn off VSA
5. let the engine rev to max redline
6. use the obd2 info to monitor cool down in between runs
7. ask for the dyno run files in additon to the printout when done
#421
Time to Climb
#424
is glad to be back!
just got back from the dyno. power= 234.50, torque= 175.88
done on the same dynojet i went to last time. SAE Smoothing 5. 91.78 degrees. good enough for me
shit reading the above comments i noticed you guys said to turn off the vsa. frick what if i didn't?
#426
is glad to be back!
You will know it if VSA was on during the runs, as the car would feel like hopping on the roller.
#430
Special-K
#432
is glad to be back!
Originally Posted by PrecyseStylez
Is this the stock charger?? I heard that your running the full Mugen Exhaust System? Auto? What are your complete mods?
#434
Nice numbers, man
Can you rerun the dyno graphs for Uncorrected, Smoothing 0? I'm curious to see what you actually put out on the dyno @ 91F. It's been 75-85F (93F today) and I can feel some (expected) power loss in the warmer weather.
#435
Btw, I noticed the numbers look a bit low compared to what I hit (15-20whp/10-15wtq).
Beyond the Mugen vs Comptech part difference, did you check how much boost you're getting? It could be that you're not at the 5-6psi you're supposed to be getting.
#436
Time to Climb
then in that case, my vsa was on. does it really make a difference??
#437
Time to Climb
just got back from the charlotte meet in blistering heat (98F). did 3 dyno runs and hit 186 hp (they didn't provide tq figures) on my best run. the 3 runs were conducted within a span of 2 min so heat soak may very well have been an issue too. those numbers aren't bad considering i've got an auto, need new header and cat, and still haven't reflashed yet. so maybe 200whp is possible (check my sig for all mods). i'll scan the dyno from work on monday and post. my buddy chris (coolcarguy) has a vid of the 3 runs but i don't know how to post since it's over 100mb, anybody have any suggestions? EVERBODY was commenting on how great the exhaust note was i was surpised myself how unraspy and mean the growl was at wot from outside the car!
#439
^^186, that's pretty good. that resolves to about 218 at the crank. It would have been pretty neat to see what you've gained throughout the torque curve.
Is this calculated by the newer SAE standard or the old?
#440
Time to Climb
^ the hell if i know! i was toooo damn hot to even think to ask that. seriously, it was torture out there. i'll dyno again once my new header, cat, p2r img, and hondata have been installed. e.t.a. about 2 months
