Torque Specs?
Old May 4, 2007 | 10:24 AM
clee109's Avatar
I Quit
Torque Specs?
Looking for the torque spec on the bolts from the exhaust manifold to the cat and the cat to the exhaust, and the o2 sensor. Thanks for the help!
Old May 4, 2007 | 10:31 AM
Reach's Avatar
25 lbs/ft for the bolts, 33lbs/ft for the O2 sensor according to my manual.
Old May 4, 2007 | 11:36 AM
Audioserf's Avatar
boost owns
Thanks Reach, good to know! I'm doing my catback install tomorrow.
Old May 4, 2007 | 12:02 PM
JTso's Avatar
Personally, I would hand tight the O2 sensor like you would a spark plug and apply anti-sieze.
Old May 4, 2007 | 12:04 PM
curls's Avatar
Someone stole "My Garage"
That's what I did (and was told by Acura)
- apply anti-seize (or if its a new OEM sensor it'll have some pre-applied)
- firmly finger-tighten
- use wrench or O2 sensor socket+ratchet to turn 3/8 to 1/2 a turn. *edit: you will likely feel the crush-washer deforming -- this is approx. when you are done tightening it*
- drink a beer, you're done.
Old May 4, 2007 | 12:15 PM
PACman's Avatar
I also hand tightened the O2 sensor (and yes, the anti-seize should be on the OEM replacement).
08KBP_VA
Oct 22, 2019 01:55 PM
emailnatec
29
Sep 28, 2018 04:27 PM
jsonkimz
Mar 28, 2016 07:49 PM
knight rider
Mar 4, 2016 08:59 AM
Tribalheads
Sep 29, 2015 03:24 PM
