Test pipe anyone?
I just got done putting together a test pipe and did a quick test before leaving for a business trip. I only had time to perform a pre-test with a scan tool to monitor the secondary O2 sensor activity and compare it with the reading after the test pipe. The reading seems normal and no CEL yet after a short drive around the block. I will follow up with more info once I return home.
I know most people use two anti-foulers but one seems to be good enough for the TSX as the O2 sensor is no longer in the path of exhaust flow. I drilled the hole completely through the anti-fouler. However, if I have to do it again, I think drilling the hole large enough to house the O2 sensor tip should be good enough. This retains the small opening at the tip of the anti-fouler. Some pics... Test pipe http://www.tsobad.com/jtso/Images/Te...st%20pipe7.JPG Test pipe and high flow cat http://www.tsobad.com/jtso/Images/Te...%20compare.JPG http://www.tsobad.com/jtso/Images/Te...st%20pipe2.JPG http://www.tsobad.com/jtso/Images/Te...2%20sensor.JPG http://www.tsobad.com/jtso/Images/Te...est%20pipe.JPG Anti-fouler Just enlarge the cavity without drilling through should do the trick. http://www.tsobad.com/jtso/Images/Te...ti-fouler2.JPG http://www.tsobad.com/jtso/Images/Te...ti-fouler1.JPG |
interesting
the man never stops! is there any mod that you can't just knock up yourself haha
You going to sell those? I want one.. :)
Once again, that is very pretty work! Though I know it is highly illegal, I'd wager the TSX runs pretty damn clean with no catalytic converter.
looks good! hows the gain JT.?
Nice! :)
Can't wait to see the results. How has this effected your exhaust sound? |
JTso, your welds are getting very professional!!! Nice work and look forward to the dyno results.
Very nice fab job :thumbsup: I wonder if this will yield gains without the ability to tune the car though.
Yes, can't wait to see the dyno. :thumbsup:
Thanks guys! I will hit the dyno when I return home from my trip. I don't think it increases any significant amount of noise comparing to the high flow cat. If it did, it's not noticeable like installing an aftermarket exhaust system.
The pipe and O2 bung are stainless but the flanges are mild steel. I wish someone would sell some stainless flanges. Currently, I can buy the rear flange but the front flange is still being hand made. If anyone knows where to get custom flanges made, please let me know. |
I need to go get an anti fouler for my comptech header and rt cat setup cause I have a check engine light that wont go away. Also my car is idling at 500rpm and has stalled on me twice.
Originally Posted by Black_6spd
Any prediction on A/F?
:ninja: I know you have a 5AT... hahaha |
Watch out Johnny! If "the gen" finds out you can machine like that, they're gonna move you from your 4th floor "baller" seat to the C.U.P. and you'll loose your Space Needle view.
i am game for one. i am actually having one made right now, along with having the resonator cut out for a little more growl.
Sounds good.
damn. how many things are you gonna make? :troutslap
how about making me a fridge? |
Originally Posted by moda_way
Stop dropping the clutch. :thumbsup:
:ninja: I know you have a 5AT... hahaha :ninja: 6MT > 5AT :ninja: |
how about making me a fridge? Just borrow from your new equity and mod the TSX even more. That way, all interest on the mods will be tax deductable. |
JTso, what size drill bit did you use to enlarge the cavity in the anti-fouler?
Thanks, Colt.
Do a stepping drill method. Remember not to drill it all the way through. Btw, I just did one like 2 minutes ago. :D
Anti-foulers! :ugh:
When I was 16 and got my first car ($400 '75 Ford Granada...don't ask I'm old okay) it would burn oil like crazy. So I would pull the sparkplugs once a month and use a brass wire wheel on a drill and clean off all the build-up. After doing this for about 6 months I saw a set of anti-foulers at a local autoparts store. I thought sweet, no more pulling the plugs and cleaning them all the time. Well I installed the anti-foulers over my plugs and the car ran great!!! It turned into a monster, great throttle response, awesome pick-up....heck I could even do a 1 wheel burn-out if I put the rear tire on some wet leaves! It was about after one week that the first spark plug blew out of the engine on my way to school. It was completely melted, as were all the others! Point of the story is don't use anti-foulers as anti-foulers! |
so..umm....did you get a chance to dyno?
I just clamp the fitting on a vise and use a hand drill.
When are you gonna take your car to a dyno to see what gains the test pipe yielded? :)
Some quick updates... I took the car out for a spin after a week of being away. The test pipe does seem to make the exhaust slightly louder. The secondary O2 sensor reading with the updated anti-fouler appears to be normal as if a CAT is installed. Still no CEL under various of driving condition. However, there is an increase of exhaust odor when the car is in the garage idling.
I probably won't take the car to the dyno until version 2 is ready. V2 will be a resonated test pipe to allow free flow without the noise. :) |
What kind of air fuel ratio where you getting from the ECU via the ODBII port?
Did you get a chance to test that yet by chance Johnny? Thanks for the update :thumbsup: |
To be more specific, do you have the air fuel ratio while the ECU is in open loop mode?
Does the scan tool you have display whether the ECU is open or closed loop mode? |
what is a test pipe?
Originally Posted by drunkenbuda
A pipe he is testing. REplaceing his CAT. Read his first post my man.
Are you planning on sellings these? :)
Update... dyno results
I decided to dyno the test pipe today. The weather is about 19 degrees warmer than the last dyno in May. There result is about the same as my high flow cat = no gain. The main difference is the leaner A/F.
http://www.tsobad.com/jtso/Images/Te...ipe%20dyno.jpg |
