Supercharger owners: does your dipstick pop up?
yup.
I was filling up at a gas station and went to check the oil level...and I noticed that my dipstick had popped up a little bit. Initially, I thought I just forgot to push it all the way down the last time I checked, but then I came home and saw this thread:
k20a.org thread
I followed the links (product here and s2k forum thread here) ...and most of it went over my head, but it sounds like this could happen to us as well?
Anyone else notice their dipstick popping up unexpectedly? I found it interesting in the s2k thread that they mentioned Comptech recommended the KrankVent product...
Or maybe I'm crazy, since we're running such low boost. Would there be any way to test the pcv valves? I need to get my oil catch can back on...
k20a.org thread
Hi there guys.
Let me clear up a few things about that product. The PCV is suppose to keep out boost that is what it should be doing. Also, saying the krank vent units are not functional as well is inaccurate...very inaccurate. Comptech has recently done testing on the factory honda PCV valves under low boost conditions (6-7psi) and found that they blow through completely. It's actually a drastic amount the vehicle blows though. When comptech tested a supercharged S2000 with the krank vent unit, they made some significant gains and issued a notice recommending the krank vent units to suppliment their supercharger kits. A certain NASCAR builder has also started equiping the cars with a different version of the Krank Vents for N/A cars because it helped to greatly smooth out the torque curve.
The way the Krank Vent mini turbo kit works is that is creates partial vaccum inside the motor. The partial vaccum helps the piston rings seal better and keeps oil vapors from blowing through and back into the intake track slicking everything (including the intercooler and reducing its efficiency) plus causing detonation because of the oil burning in the combustion chamber.
The dipstick popping up is the first tell tale sign that you are having a lot of boost seeping through the PCV. Failure to keep the pressure out of the crankcase has cause plenty of engines to have their ringlands fail and destroy their motors. The Krank Vent units are basically like super PCV valves and very fast acting. There has only been one failure in the years they have been around and that was with a ~2000psi pressure wave from a motor blowing up. You can either keep the existing PCV and put this inline (to save time on installation) or you can remove the factory PCV unit and place fittings on the valve cover to have them run.
On the boosted S2000's the lowest gain I have seen was 18whp and the highest has been 33whp. We will be doing one final test of our own with a 600whp S2000 shortly to see exactly how much we can pick up on the more powerful S2000's. Before I started to sell them, I saw them personally and was absolutely amazed. It's one of the products I am very glad to carry and be the sole honda distributor for because it's not that expensive for all that it can and does do. From the first day that I was boosted on my S2000, I had the dipstick poping up problem and this unit remedied that for plenty of people. The viper and boosted ferrari guys swear by these units.
That is not true. We just don't have any data to back-up any claims on honda engines just yet. However, some NASCAR builders are using the krank vent items now and those engines are N/A. They have not seen significant HP gains but their torque curve has smoothed out greatly especially in the low-mid. These units have a patent for being the only kit that actually creates partial vaccum in the crankcase which has the main benefit of allowing the rings to seat properly.
I haven't looked real close at the intake setup on my TSX, however I seem to recall a hose connecting the valve cover to the rubber hose between the throttle and the air filter. In a supercharged application, this hose would not be under positive pressure. Exactly how does boost pressure act on the PCV valve in that case? I would assume that cylinder blow-by would increase a bit with forced induction, but we aren't talking about that here, are we?
Originally Posted by JTso
My question is how exactly does the Krank vent create vacuum under boost? How much vacuum?
Btw, if there is any pressure build-up inside the crankcase, it would go out through the valve cover vent tube during boost.
Cylinder blow-by does increase with F/I and that adds to the crankcase pressure which actually overwhelms the system with the factory PCV setup.
We have seen nothing but gains and happy customers with these units. As I had stated, on a supercharged S2000, we are gainning a good bit of hp. I wouldn't doubt if our sponsored 600whp S2000 doesn't end up gainning 30whp from this mod at all. At the very least you have a PCV valve you can use on any car because these are universal and should last a lifetime.
Sounds like a simple solution. It is basically a check valve that prevents positive pressure from acting on the "manifold-side" of the PCV valve--effectively turning the "vent" on the valve cover (the aforementioned hose connecting between the air filter and throttle) into the primary PCV port.
In a weird sort of way, this retains the "normal" functionality of the PCV system, even under boost.
The PCV valve is meant to meter crankcase vapors into the intake manifold. It is the pressure differential and timing of pulses in the vacuum of the intake manifold that make it work. At wide-open throttle, the pressure inside the intake manifold is theoretically at atmospheric... so the PCV valve ceases metering.
The addition of the check valve between the manifold and PCV valve effectively returns this ratio/balance of pressures.
Originally Posted by kane.s2k
both valves flow out of the crankcase. Hence why it can create a vaccum under boost and normal driving conditions.
At light load when the intake manifold has a vacuum, I'd wager that the PCV valve will be the only one emitting crankcase vapors. And at full boost, I'd wager that the "vent" side will be the only one emitting crankcase vapors.
JTso, that is a good observation--However doesn't the vent side of the TSX already have an oil separator? That box thing attached to the intake hose? I'm sure the valve cover offers some kind of buffer as well.
junktion, you have nailed it on head. Thank you. I'm sort of in a mad rush right now so not everything might have been very clear.
I wasn't referring to the krank vents at the same time. I mean that that is just how they work. One the both pull out of the crankcase not neccesarily at the same time.
JTso, I think you are missing the point I am making and also what I am telling you our testing has shown. Comparing a completely open system to ours and calling it equivalent is incorrect and unfair at best. Engineers would not go through the hassle of designing a PCV system including location and passages if they could just drill a bunch of holes.
Plus that wouldn't be environmentally friendly
Here you go, a thread on oil consumption (btw, the maker of the thread is not sponsored by my company or the maker of the krank vents as a matter of fact I'm sure he hates my guts so he has no reason to make up results).
http://www.s2ki.com/forums/index.php?showtopic=395314
Fair enough
I am just trying to get people aware of a product that has been very good to the S2000's guys so far as well as other cars. I was actually looking for info on the TSX engines for a special request from a friend of mine when I stumbled on this.
I was surfing around the net looking for more info on the krank vents.
It seems that some people are reluctant about installing the larger krank vent on the breather side as it would eliminate the fresh air flow. Some people have opted to only install the small krank vent on the pcv side.
I found this link regarding the krank vents:
http://www.stealth316.com/2-krankvents.htm
A major reason for fresh air flow into the crankcase is to get the acidic gases out of the crankcase which would lower the pH of the oil. However, many modern day high quality oils come with a large amount of pH buffers like potassium to maintain a balance in the oil. If you do your oil changes in the appropriet 3,000 to 3,500 milage intervals I see no reason why it would be a problem. However, I don't have any data to prove this and it is a very good point you have brought up. So that will be the next phase of testing I will put them through some oil analysis.
You can use the krank vent on just the PCV side and you will basically now have an actual workign PCV.
I'm curious... let's say i were to get the supercharger, I would be interested in installing the krank vent at the PCV side. I have attached two pics of the SC in a TSX.... (thanks in advance to Tsx536 and Steve457).. Where would the PCV hose be located and in which direction should the flow be going? Thanks
Rep'n Taxbrain.com
Actually when I asked Comptech about this they said that the PCV valve on the TSX is before the blower so the PCV valve will never see any boost.
They said it's the S2000's that have been having the problem with the PCV valve seeing boost.
Fool
03-10-2016 08:42 PM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
Joe Avesyan
09-29-2015 03:57 PM
