Stiffy Torque damper and NST pulleys
can I run the torque damper with all 3 piece nst pulleys? I read somewhere that having the idler would be in conflict with the stiffy is this correct?
how hard is it to install the damper? is there any picture step by steps on this?
I am a bit confused with pulleys would it be ok to just use the underdrive crank pulley instead of alt/idler? since i wont be using a system etc..what are the pros/cons of just using the underdrive crank pulley VS having the whole kit?
fyi: please use the search button in the future
but to answer your question, the Stiffy ETD will not interfere with the idler pulley because there's plenty of clearance.
There's plenty of guys out there who's running either UR pulleys, or NST with different ETD's and not having problem with any of them.
IMO, if you're deciding to go with the NST, you really should buy the kit, along with the recommended belt, because it comes with an
under-drive crank pulley, BUT with an over-drive alt pulley.
*Running an under-drive pulley alone is not really recommended, but please do your own search on this one.
But, if you're planning to go with the crank-pulley, i suggest getting either the UR or the Alutec because you can run OEM serpentine
belt on both and not really have anything to worry about.
Installing them would require tools and some ingenuity, which anyone on the board to post here, but i think
searching would be better for you.
Goodluck!
Goodluck!
boost owns
If I didn't have my stupid supercharger belt tensioning mechanism in the way, I'd still be running my Ingalls ETD. It's a good product.
i think it was JTSO or a guy from OZ Honda who did this mod. Better to have it than not, right?
boost owns
I miss my ETD. I hope CT-E are still selling auto-tensioner mechanisms next year when I get back into the modding game.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
