springs vs coilovers
Originally Posted by AZTSX
i am wondering how much will springs camber kit and konis cost compared to coilovers do i even need a camber kit if i do decide to get coilovers thanks
you can probably get springs + Konis for around 800 bux or less. coilovers will run atleast 1100 or more i'd say. you'll need a camber kit for either most likely if you plan on dropping and inch or more.
Since i can do the install myself i wouldnt have to worry about labor. That being said it wouldnt matter if i got the springs then the konis later however if i decided to go that route it would only be 300 cheaper if i did get the shocks ...Also are you able to adjust firmness of ride with either setup? HMmmmmm decisions decisions!!! thanks again for all your help
MrHeeltoe
20
02-23-2023 02:54 PM
MrHeeltoe
09-29-2015 11:43 PM
MrHeeltoe
09-28-2015 06:43 PM
4drviper
09-23-2015 08:42 PM
