Secret Weapon Intake question
This might sound noobish but i need to know if this intake fits on my 08 tsx, it says its for an 04, 05 but i just wanted to double check before i pulled the trigger, thanks, any info you have would be appreciated
link:
http://cgi.ebay.com/ebaymotors/Weapo...Q5fAccessories
link:
Oliver!!!
Somebody please correct me if I'm wrong, but didn't they change the diameter of the intake on the 06 - 08's? If so, I don't believe this will work with the later years.
Oliver!!!
Yeah, the throttle body did change. But I think there was a change in the diameter of the intake as well. Part of the redesign.
Okay, I found it. They increased the intake duct radius from 70mm to 80mm. They also increased the intake manifold bore and the throttle body diameter.
http://corporate.honda.com/press/article.aspx?id=2836
Unregistered User
^Yes, they changed the intake tube diameter from 70mm to 80mm, throttle body from 60mm to 64mm, intake manifold allowd 110L of air per minute instead of 04-05's 90L / minute. Short ram intakes might feet, tho
cycdaniel
12-17-2019 10:58 AM
mrkingstonvi
02-22-2016 01:53 PM
