Safe to change HID bulbs?
Drives With Hands
Nothing to fear. The high voltage is only really present during warmup when the ballasts emit the "whining" noise. Running voltage is around 80v and turned off, they'll not carry a charge as the ballasts have internal bleeder resistors to dissipate the charge of their internal capacitors once power is removed.
7th Gear
changing hid
Hi, I changed my bulbs with 6000K and it was quite easy to do. Just follow the instructions in the manual. You need a special screw tip to open a screw. I used tongs to unscrew it. Everything else was simple. Good luck
if u dont mind me asking, how much was the bulbs? what brand?
any pics ??
thanks
Yohan
the bulbs? they were not cheap, around $150 - $200 for a pair. I got myself the Philips Ultinon 6000K, they were an amazing replacement for stock. Snow white colour and very even beam.
Photography Nerd
Originally Posted by narci
Hmm...with a higher intensity bulb, does it draw more power? If is draws more power will it melt the wiring or housing over a period of time?
Also, K is just a measure of the color of a bulb. It really doesn't mean that it's any more "intense". 4300K is widely considered white. Lower numbers are more yellow/red, higher numbers are more blue/purple.
Registered Abuser of VTEC
Originally Posted by Dan Martin
Power is measured in Watts, not K. So long as the wattage stays the same, the current will stay the same, therefore it won't cause any additional stress on your wiring.
Received 3,791 Likes
yea you will be fine I even swapped out the complete headlight assembly and moved the factory bulbs to the new headlights long with the ballasts and I have had no problems.
Photography Nerd
Originally Posted by youngTL
I wonder where that number comes from? Is that like what colour a star would be if it's surface temperature was that? No, it can't be that (astronomy tells me otherwise). It must be something else.
Originally Posted by me_kevinly
is there any special bulb size for the HIDs????
i notice on ebay there D2C and D2R, whats the difference?
which one is right for us?
D2S - Projectors
D2R - Reflectors
BoricuaTL
04-08-2016 01:08 PM
