Red Shift Motorsports
#41
I think if the kit gets done then engine can get done too. both and hondata own tsx's i believe and want the boost personally or so i've read. but hondata never tells people what they are working on either unfortunately, thats a direct quote from their website. I'm going to stay optimistic, I hadn't put any money down or anything so i've got nothing to lose by hoping they can pull it off
#43
Received 3,763 Likes
hondata is doing the engine management
#47
I dont see how you can say it is delayed as I have read nothing about that in the thread on clubrsx and also heard nothing about that from chris at . yeah they had a 2 week time where it wasnt worked on cause of family problems but geez give it time.
#49
Is waiting in
** latest issue of Honda Tuning shows new fuel injectors from Venom for K-Series motors and they're a direct replacement for the OEM, no fuel rail needed. Maybe that can be of some help to us....
#50
Rep'n Taxbrain.com
^^ Yeah hopefullly that is a soultion we can use on the TSX. Hondata reported flooding upon cranking when they tried to used hi flow injectors on the TSX before. This was quite awhile ago now, so hopefully this has been solved.
The other problem that can come up is adding fuel under boost conditions. The Hondata reflash for the Comptech SC actually does not handle the fuel management under boost conditions. All of the fuel is being adding with Comptech's Piggyback ACM module. I believe they had to go this route because Hondata was not able to add fuel under boost conditions. This was primary because when the ECU sees boost from it's MAP reading, it throws a CEL. That was another reason why the Comptech ACM was needed. The ACM also clamps the MAP sensor voltage, so that the ECU never sees boost.
Hopefully, Hondata is now able to add fuel under boost conditions and prevent the ECU from throwing a CEL. No one really knows what their capable of with the TSX ecu yet though. As mentioned above, their development is kept secret. Hopefully the worse case scenario is that they are able to add fuel under boost conditions, but you would just have to live with CELs. If you're running high boost, I think it would be worth it. Just put some black tape over that area![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
Anyways, those are the issues that we know of that can prevent the RS SC kit of being finished really quickly. Who knows, they might even have a solution for it CCColts. You should talk to them and get more info on how they are going to handle the engine management.
#51
Rep'n Taxbrain.com
![Sad](https://acurazine.com/forums/images/smilies/sad.gif)
#52
mmmmmm....
Originally Posted by Tsx536
Yeah, I've been reading that same thread on ClubRSX for a couple of months now. Keep in mind, that the RSX guys have KPro though. If we had KPro, then the engine management would be no problem. But we don't ![Sad](https://acurazine.com/forums/images/smilies/sad.gif)
NOT!!!!!
:troutslap
#53
however going by that approach it almost seems to make more sense to just do the RHD drive conversion and use the k20 from the euro r with its cable throttle and then.
#56
Rep'n Taxbrain.com
well I have been toying with a way to use the kpro on my car. so far what I have come up with is to use custom gauges obviously and then use a heat unit and cable control setup from a earlier year accord since it would be standalone. put the controls in the glove box. once this is done then I could switch to a cable throttle body from the accord or the rsx. once that is all said and done I could use the kpro.
![Drool](https://acurazine.com/forums/images/smilies/drool.gif)
I think we are all hoping for Red shift to have an engine management solution that is directly plug-n-play and can be used for all TSXs without having to lose any of our comforts. If you can, try to talk to Red shift about it. I'm guessing that they probably already have some great ideas for engine management
#57
Originally Posted by HaPPy jU1cE
is it possible to just have 2 ecu's one for the gauges and one with kpro for the motor? sorry probably a stupid question...
Additionally, Doug has K-pro on his TSX. How do you think he got that to work?
#58
Originally Posted by Black_6spd
Don't laugh -- of course it is. 05/06 RSX-S owners don't have a K-pro for their specific application, so they have to use a jumper harness which pretty much does what you described.
#59
Sounds like a pretty cool idea since yours is a show car and not a daily driver. If you could run KPro that would be awesome ![Drool](https://acurazine.com/forums/images/smilies/drool.gif)
I think we are all hoping for Red shift to have an engine management solution that is directly plug-n-play and can be used for all TSXs without having to lose any of our comforts. If you can, try to talk to Red shift about it. I'm guessing that they probably already have some great ideas for engine management![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
#60
K-pro won't work on AT car.
taken from Hondata website:
The K-Pro ECU will not work on Automatic vehicles. Automatic ECUs cannot be converted to manual.
http://www.hondata.com/kpro.html
#61
#64
IMO...it takes time to comprehend an ECu unless you are the one who designed it, and Honda/Acura doesn't hand that information out to ANYONE. I dunno I just think somthing WILL work If not then
But rember I am a
so what do I Know
![Moon](https://acurazine.com/forums/images/smilies/moon.gif)
![n00b](https://acurazine.com/forums/images/smilies/n00b.gif)
#65
But rember I am a
so what do I Know ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
so tell hondata that the twinscrew is coming and they need to hook us up!!
#66
Rep'n Taxbrain.com
IBTL....
![Im New](https://acurazine.com/forums/images/smilies/imnew.gif)
Wouldn't you think that with a combination of piggyback and re-flash somthing would work? I mean no car is "hack" proof.
I think that will very much work. I was just wondering if you've happenned to hear if Red shift has developed a piggyback for the TSX yet? And will the piggyback handle the fuel management or will the reflash?
#67
Rep'n Taxbrain.com
But rember I am a
Good luck though "
#69
hi "
" :wink:
#70
IMO, I don't care if it takes a while to come out, I just hope it comes out. And I also hope that Hondata has figured out how to control more of the engine management than they could before. ![Wish](https://acurazine.com/forums/images/smilies/wish.gif)
#71
Mugen freak
I posted this in another thread, but no one replied. Why cant this product http://www.synapseengineering.com/pr...ink/ml001.html be used on the tsx? Its purpose is to fool the stock MAP sensor into not detecting boost, while still compensating for changes in engine voltage, etc. Heres an excerpt from that site if you are too lazy to visit it.
"This approach to "tricking" the ECU from seeing that the OEM normally aspirated engine is now producing boost, also allows the ECU to compensate for changes in operating altitude. Electronic solutions that limit the voltage of produced by the MAP sensor under boost, also known as voltage clamps, will always show the ECU the same voltage regardless of changes in altitude, weather and barometric pressure. Voltage clamps eliminate the ECU's ability to dynamically adjust to atmospheric changes. For example, a vehicle in San Diego, CA will see a change in barometric pressure simply by going from the beach (sea level) to the mountains. With a voltage clamp, the ECU would see the same voltage at all altitudes. Missing Link is a solution that allows your car's ECU to make adjustments in fuel and timing curves to compensate for these changes dynamically.
Since the Missing Link is not a bleed valve, it will also allow you to dynamically change boost without making any adjustments to the valve."
#72
#73
Mugen freak
Originally Posted by rza49311
maybe I'm reading the site wrong but i don't see where it says it works with a k24 ![Why Me](https://acurazine.com/forums/images/smilies/whyme.gif)
#74
Rep'n Taxbrain.com
Does it only control the fuel and timing?
What about changing the Vtec engagement point?
Also, I'm guessing this would have to be dyno tuned. That could get expensive, but it could be do-able I guess. I don't know much about this certain engine management solution. In general, sounds like it would work in theory, but it would not control other things besides timing and fuel. I'm not sure why a shop would even recommend this for a K20 when KPro is out there though.
Hopefully someone else with more knowledge can comment. I do remember AEM talking about releasing something similar: http://dcsports.com/ViewCategory.aspx?CategoryID=116
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
Hines57
09-24-2015 01:58 PM
