Recommended Camber spec?
Whats do you auto crosser recommend on camber spec for front and rear.
I'm a spirited driver who takes free way on ramp and exit ramp like a I'm on a race track and once a week .. hit the twisties in the mountains.
Keep the fronts at barely negative, -1 at the most I would say - and keep the backs at -1 - 1.5 depending on how "stable" you want the car to feel while driving straight.
Stock specs should be something like...
Front= 0.0
Rear = -1
Front= 0.0
Rear = -1
If you dropped it without a camber kit your front wheels would go to negative camber, which is what you want. The rears would require a camber kit, as your toe would also go out of spec pretty horribly (front is double wishbone, rear is 5 link, so your front is less sensitive to camber change under articulation, which is why a camber kit might not be needed on the front, depending on the drop). But yes, a drop would definitely help - but only if you get new springs and new shocks. I wouldn't do it any other way. Personally, I think the A-SPEC kit is definitely the best deal for our cars.
got Nuespeed Koni + sport spring & CT RSB w/ poly bushing with ingalls rear camber kit. So i guess i'm gonna lower the front a little more to get more neg camber and posibbly get more planted feeling
emailnatec
29
09-28-2018 04:27 PM
adreano17
09-29-2015 08:48 AM
