Is this for real?? Load of crap I think
20+ HP with radioshack resistor?! This guy must work for Michael Schumacher's team. Fishy, tuna fishy...
http://cgi.ebay.com/ws/eBayISAPI.dll...907087925&rd=1
Originally Posted by TSX Cman
its like 10 bucks... im hoping someone will experiement for the hell of it
it garuntees no damage. so you could put it in and take it out. and throw it out even.
This is his whole angle. Scam a little bit of money from a lot of people.
Stokeless
Originally Posted by TSX=XTC
Just a little FYI
"Lemmiwinks" or diodes
do allow CPU modulation...
Heres a DYNO for you...
2003 GTI 1.8T with STOCK ECU AND STOCK TURBO
with a 4.3w diode
Obviously it can be done, its called
VOLTAGE CLAMP
or
MAP CLAMP
I never said it was possible with A TSX..............reread my statement
with a 4.3w diode
VOLTAGE CLAMP
or
MAP CLAMP
http://minimopar.knizefamily.net/perf/mapzener.html
some good reading on diodes
Obviously not for the TSX
say hi to new stuffs....
those voltage stablizer that is recent hot in Japan is basically sth like a diode.
Well, I know it is hard to make people believe here.
Let's wait another year and people in N. America should start discussing.
Not sure about the diode but the resistor trick has been around for years. It's the same IAT mod that Jackson Racing uses for their SC setup by modifing the IAT resistance to trick the ECU to add more fuel. The JR implementation utilizes a pressure switch and relay setup which connects the add-on resistor value to the IAT circuit at approx. 1 psi of boost at the intake manifold. This is an attempt to add fuel during transition to boost to avoid detonation. By adding this resistor to NA setup will cause the engine to run rich all the time including idle, which makes this mod pretty much useless. I can sell anyone who want this mod for only $5.
joflewbyu2
10-08-2015 11:16 AM
Sarlacc
Console & Computer Gaming
09-30-2015 02:15 PM
