Is it possible to increase the compression ratio of the engine?
I discovered that the type-r engines usually have a higher compression ratio to give a high hp. So, I wonder whether we can increase the ratio to gain performance.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Photography Nerd
It's already 10.5:1 which is pretty high. You could probably get it up to 11:1 on 93 octane but anything higher would likely cause detonation if you didn't run race fuel.
Realtime runs 12.5:1 on their TSX but they also use 112 octane.
Photography Nerd
Originally Posted by ignatiuslee
oh ic
thx very much
that means we couldn't use the type-r engines here because of our fuel...
thx very much
Photography Nerd
Originally Posted by TSX 3Pedal
I want 93 octane fuel...
The hightest that I have seen is 91 octane here in California, as far a I can recall, and that's what I use...
![HaHa](https://acurazine.com/forums/images/smilies/haha.gif)
I use Sunoco 94 on a regular basis up here. :P
Does lower octane make for a cleaner burning fuel?
putting higher octane gas in your car does not affect your car's comprasion ratio (just in case anybody read the above threads incorrectly).
another myth... placing higher octane gas in a car that requires regular octane will increase performance.
this is completely FALSE.
lastly... what octane method are they using... 93 octane here (USA) is the same as the high octane gases found in europe.
Not to mention, just about everywhere around where I live you can get 107.
Photography Nerd
Photography Nerd
Originally Posted by AZTSX
Mmt?
Reader's digest version:
Originally Posted by the article
A few years ago, Honda found that oxygen sensor failures were considerably higher in Canada than in the U.S. The automaker also found that manganese-coated sensors signal the Electronic Control Module (ECM) to enrich the air/fuel mixture, which increases hydrocarbon and carbon mon-oxide emissions.
You could use a Spoon Head Gasket and not have to use higher octane (without worry of detonation).
Teh seX
1fatcrxnem1
22
06-01-2018 01:23 AM
09-17-2015 09:01 PM
09-15-2015 06:44 PM
