LOL YA? whatever happened to that dyno for those custom headers you had made for you. that was forever ago haha get it dynoed ASAP
we definitely need at least one more option for headers
we definitely need at least one more option for headersWAS HONDATAFIED IN
the injen cai (which i have) and i believe all cai's will cause this...... at low rpm you catually lose a little in torque. i believe this is until about 3500rpm, then it starts to go up. when vtec kicks in at 6200rpm then is where you "feel" the power. i believe that headers will also cause the same result. i think when you add i/h/e (intake/headers/exhust) then you start to see an overall gain. but that is about $1600 in mods (depends on what componies you choose). the best bang for the buck is the cai.
I wouldn't worry about hydrolock because the tsx has the plastic cover on the bottom of the car that helps on not allowing water. i think that the only way that it will hydrolock is if you drive for a few seconds in 2 foot deep water (not a 2 feet puddle).
and i also agree that the rims/wheel combo is very important. the tsx rims weigh about 21lbs each. the tires i believe they are 29lbs. that's 50lbs per corner. remember that tires/wheels are unsprung weight (weight that you need to move (rotate) in order to make the car move. keeping weight down is also important, but unspring weight is critical. i heard somewhere that the rule of thumb is that 10lbs of unsprung weight is about .1sec in the 1/4. so in theory if you get wheels that are 17lbs and tires that are 26lbs, you have a total of 43lbs. that's a saving of 7lbs. x4 its 28lbs. in theory that would be almost .3 in the 1/4 faster, not to mention that summer tires you get more grip and you get a better launch and will be faster that way also.
i think that if you want to gain low end power you should look into light weight tires/wheels. i think that is the best solution.
