New Comptech Heatshield
Professional Newbie
Looks like Comptech came out with their own IMG
http://www.comptechusa.com/store/product433.html
How do you guys think this compares to the Hondata heatshield?
It says it's 3.4mm thick and transfers less heat than competing gaskets
Bye TSX, hello domestic?
Originally Posted by CGTSX2004
hmm...if it's rebranded, they're selling if for less than Hondata...
Which reminds me...anyone wanna help me install a Hondata gasket on my 06 next spring?
My Garage
Originally Posted by JTso
It's about the same thickness as the Hondata IMG but the material is different.
I think the Hondata gasket ran for about 60
Professional Newbie
Originally Posted by kyotousa
you need to take off the whole engine to install right?.....
or just manifold.......
Originally Posted by chuson
Approximately how many HP/Torque gain or temp drop with this mod?? and How much for Installation in general?
Professional Newbie
Originally Posted by xizor
no way do you need to remove the engine, you just need some dexterious hands and swivel extensions to get at some difficult bolts
C'mon, man! Row yer own.
Based on my recent short-shifter install, during which I had half the interior of my car spread out on the garage floor and narrowly averted disaster (only to have this happen to me afterwards), I'm going to lay off the "taking-a-ton-of-stuff-apart" mods.
High-flow cat? No problem, solid gains, six bolts. Oil catch can? Maybe, fairly simple and straightforward. Disassembling entire intake tract and draining coolant (two things fraught with peril) to install a thick plastic gasket? Nope, for me that's tempting the God of One-Too-Many-Turns-Of-The-Screw.
Originally Posted by madmanmax3000
Don't you also need to drain a lot of the fluids? I'm really not into draining engine fluids...
Can I bring it to a performance store and ask them to install?? I mean will the installation fee higher than the product itself?
My first time installing the IMG was a little difficult due to lack of space to place a wrench to remove the lower bracket bolt. The top bracket was not too bad if you have a very long extension and a swivel socket. I later found the perfect combo tool to remove the lower bolt. It's a gear wrench with a socket adapter which transforms to a low profile ratchet. The right tools make the job more enjoyable.
. . . The right tools make the job more enjoyable.
Drives With Hands
Originally Posted by PixelHarmony
So I'd assume that if I get the TSX S/C kit then it'll come with this upgrade =T There goes my Hondata IMG install plans for this winter.
BoricuaTL
04-08-2016 01:08 PM
