A LOT of vibration from RT Cat
Old Oct 16, 2006 | 08:32 PM
kendroz's Avatar
After 2 months with the RT Cat, I got a vibrating sound when idle with the AC on.
I change al the rubber hangers (6 in total) and the anoying sound still there.
I dont known if unbolting eeverything and bolting it back will fix this.
Any suggestions will be welcome, and thanks a lot for your support.
Old Oct 16, 2006 | 11:39 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Did you put any gaskets in?
Make sure that the cat is tightened down well on both the header and exhaust sides. Since the RT Cat has the floating flange design, you have to get it pretty tight. Also try pushing up on the cat/header while you tighten.
Old Oct 17, 2006 | 12:11 AM
chuson's Avatar
T.DoT P.I.M.P. lol
Maybe it's touching the Heat Shield, that's why it's vibrate?
Old Oct 17, 2006 | 01:39 AM
tigerfan85's Avatar
-phase-
i have my floating flange welded down and i am using a gasket too and experience no problems
Old Oct 17, 2006 | 07:12 AM
moda_way's Avatar
very popular issue. Follow the above suggestions!
BIGxRED
Oct 19, 2015 10:47 PM
lanechanger
Oct 13, 2015 10:56 AM
SinCityTLX
55
Oct 11, 2015 01:20 AM
joflewbyu2
Oct 8, 2015 11:16 AM
