JTso's Custom Engine Torque Damper Setup (ETD)
#321
Originally Posted by SoCaliTrojan
Why does the AT have it and the MT doesn't?
#322
Originally Posted by JTso
I just received the lower subframe vibration damper and it seems to have good clearance with the DC header.
The only thing I can think of is the AT has a lower idle rpm in drive than MT in neutral, which causes slightly more vibration.
I wish I had some science behind it but I don't. Just my experience suggests that the conditions under which the Comptech header causes the rattle would not be present on an MT, since they would have the clutch out.
*edit* Sorry, I don't mean to de-rail this thread away from ETD discussions and make it about headers, I just wanted to add an experience with the lower OEM dampner. Back on track now.
#324
Originally Posted by TSX2345
Jtso: Is the hardware included for part #14 or is it just the part alone?
If not what bolts were used for your install?
#325
Quick update on the redesign of the lower mounting bracket. I welded another bracket on the other side to provide additional support. Engine movement during launches is greatly reduced. The best part is no vibration even when AC is on due to softer settings on both ETD units. The subframe dynamic damper might also be a factor.
#327
Originally Posted by HoRRo
So... JTso, any plans to sell the final products?
If after trying the Ingalls kit (when available) and you want more, then try duplicate the under carriage setup.
#328
well after having it for over a year I finally installed my JTso V2 ETD. Installed pictures and painted pictures to come soon along with a few other changes to my car.
#331
Originally Posted by aaronng
Even the clamps to hold the AC lines are CHROMED!!!!!!!!!!!!!
#333
those are chromed, the radiator mounts, the battery tie down, and the bracket holding the two hoses by the front bottom right corner of the manifold cover. I am thinking of getting the brackets of the ETD chromed next.
#335
The black dipstick is shorter than the orange one though. He'll have to swap the sticks with the plastic handle part.
#336
Originally Posted by moda_way
Isn't it the valve cover that makes the black dip stick work? I have the stock valve cover, but the black dip stick. I thought that if you put the JDM valve cover on the black dipstick would work.
#337
Now you just need the black oil dipstick. Granted the orange matches the mugen socks, its just... wierd against the red and definitely not JDM.
#339
Hey JTso,
How effective is the lower (subframe) v3 damper alone? Without the v2 damper?
I am tired of the vibrations and would like to move my damper under the engine. Is it worth it?
Thanks!
MBA
Thanks!
MBA
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
Iakonafuji
09-21-2015 02:39 PM
09-15-2015 06:44 PM
